Graphic LCD and stamp 2
In my project are I using a 2 * 16 LCD but I got a graphic LCD that I would like to use. The LCD is using 8 bit and I am now using 4 bit in my project. How do I control a graphic LCD? I have attached the manual for the lcd. Some sample code would be nice!
- Stephen
Sabhai, for a start, I would suggest going to Google and searching on the numbers for the driver chips used in your display, the KS0107 and KS0108. That should get you started.
- Rick
