BS2p to Lantronix XPort issues
I have a BS2p ic integrated into a jet engine controler and have been fighting for some time to get my xport and bs2 to work together. The xport and bs2 are conected as follwos.
BS2
Xport
sout
Serial Data RX
sin
Serial Data TX
Atn
CP3 / DTR
Pbasic responds with no stamp detected , echo - yes , loopback - no
BS2
Xport
sout
Serial Data RX
sin
Serial Data TX
Atn
CP3 / DTR
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
With a 'native' 232 port, or even an appropriate USB one like the FTDI version, a PC can get the close timing needed. With all the latency of the network to the XPort hardware, the DTR Reset to Serial Data sent is too long a delay.
Note the BS2 does not even work with all USB to Serial devices. Using DTR to reset a serial device is not a "typical" serial port action.
Now, having said all that, it IS possible to RUN a BS2 program over the XPort.· You simply can't PROGRAM the BS2 over the XPort.
Although your application of the load and serout serin commands seems doable here.
Thanks again for your help .
