Micro_SD card breakout?? Anyone interested?
Ok...so I have been lacking getting any of my designs to the production phase.....but recently...I did get a prototype working that has a Micro-SD card on it.
I have designed a micro-sd card breakout which contains all pull ups and a 0.1uF capacitor on board.
The board is about 0.8 inches square, and has a standard 6 hole header row on board. The board will come with the header, but it will not be soldered (standard through hole part). The connections are standard (Pwr, Gnd, Do, CLK, DI, CS,........in that order ascending).
The remainder of the board will be surface mount. No other items will be on the board. A processor with the capabilities to communicate with an SD card will be required.
I figure a price of $9.98 each........
Is anyone interested?
Market research you know. ( hate Parallax just come out with a standard SD card breakout.....hate to make competition)
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
James L
James L
Partner/Designer
www.parallax.com/Store/Accessories/Communication/tabid/161/ProductID/597/List/0/Default.aspx?SortField=ProductName,ProductName
Wow...that is even worse.
But the one I'm am offering is for SPI only communication, and has pull ups on board.
Interesting.......
James L
James L
Partner/Designer
Well considering it is as small as a postage stamp......it could go in a padded envelope and be sent first class......probably pretty cheap.
At the moment....I do not have any built.....but if there is some demand...I may have some made up.
James L
James L
Partner/Designer
Why re-invent the wheel if its already been done?
James
