Using the prop as a SNES custom game test platform.
I am posting this to get a list of people here that might be willing to work on creating a snes game (one that works in a regular snes)
And a Propeller program that can "test" snes games for compatibility. (a.k.a. snes emulator)
This would involve the implementation of the following to allow testing of custom snes games without needing a real snes.
CPU reference
Processor: Ricoh 5A22, based on a 16-bit 65c816 core
Clock Rates: (NTSC) Input: 21.47727 MHz
Bus: 3.58 MHz, 2.68 MHz, or 1.79 MHz
Clock Rates: (PAL) Input: 21.28137 MHz
Bus: 3.55 MHz, 2.66 MHz, or 1.77 MHz
Buses: 24-bit and 8-bit address buses, 8-bit data bus
Additional Features
* DMA and HDMA
* Timed IRQ
* Parallel I/O processing
* Hardware multiplication and division
Video reference
Resolutions Progressive: 256x224, 512x224, 256x239, 512x239
Interlaced: 512x448, 512x478
Pixel Depth 2, 4, 7, or 8 bpp indexed; 8 or 11 bpp direct
Total Colors 32768 (15-bit)
Sprites 128, 32 max per line; up to 64x64 pixels
Backgrounds Up to 4 planes; each up to 1024x1024 pixels
Effects
* Pixelization (mosaic) per background
* Color addition and subtraction
* Clipping windows (per background, affecting color, math, or both)
* Scrolling per 8x8 tile
* Mode 7 matrix operations
Audio reference
Processors: Sony SPC700, Sony DSP
Clock Rates: Input: 24.576 MHz
SPC700: 1.024 MHz
Format: 16-bit ADPCM, 8 channels
Output: 32 kHz 16-bit stereo
Effects
* ADSR envelope control
* Frequency scaling and modulation using Gaussian interpolation
* Echo: 8-tap FIR filter, with up to .24s delay
* Noise generation
Memory reference:
Main RAM: 128 kB[noparse][[/noparse]cn 6]
Video RAM: 64 kB main RAM
512 + 32 bytes sprite RAM
256
CPU reference
Additional Features
* DMA and HDMA
* Timed IRQ
Video reference
Effects
Audio reference
SPC700: 1.024 MHz
Effects
* Noise generation
Memory reference:
256
Lolz, coming from you, that makes me worry..
So then im guessing its just too big of a task?
Of course I could be wrong so the first step would be to take a look at what baggers, potatohead and ericball have been doing on the 6502 front. This might convince you one way or the other.
I would point out that the chip used in NES was a Ricoh 5A22, yet another 6502 variant, that seems to have lots of extra funky hardware including some kind of support for mul and div.
Would be easier with prop II?
And if your stated objective is to test SNES games w/o a SNES, there are many emulators for PCs and consoles which can be used for this purpose. And if your desire is to develop an SNES game, then you are going to need to spend your time chasing that dream instead of developing an emulator for the Propeller.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
Think Big.
Then hack at it every day. For 1 hour, for 24 hour.
Plan in steps.
Always in bits.
Part of the emulation fun is just expressing one platform in terms of another. It's a kind of benchmark, or coming of age for a given machine / CPU to successfully emulate another one in a meaningful way. The side effect then is having greater availability of the original machine to new audiences, history, what if, etc...? Doing this is also very challenging because a very complete understanding of both platforms is required to make anything work.
If it were me, and I were interested in the SNES, I think I would get hold of an existing emulator (http://www.bestfreewaredownload.com/freeware/t-free-snes9x-freeware-eoddlrzg.html), and some sample code to look at. (http://gra.dforce3000.de/index.html) I don't recommend either, because I know very little about the SNES, other than I had one and liked it! Just thought an example or two would make some sense.
The good news is that the SNES has been reverse engineered well enough to permit home brew game development, meaning the door is open! So, do that on the SNES and have a great time! I'm into this on a few levels for the older Atari machines, and it's a lot of fun, good tech, and nostalga wrapped into one. I don't know about the SNES homebrew scene. I think it's small, but if it's anything like other scenes, there will be some alpha SNES owners, who would welcome new people into the fold. Good stuff, recommended.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Perfectly stated.
It is a benchmark.
The 65816 was also used in a Apple IIGS, which gave it at the time performance up there with its 68000 competitors.
Overall a nice chip.
WDC Link:
http://www.westerndesigncenter.com/wdc/w65c816s-chip.cfm
