NEW SD Card Adapter from Parallax — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,940
edited 2009-10-09 18:51 in General Discussion
I really like the new SD card Adapter kit and have it on my list. I think I will use this as a backpack/holder for Mctrivia's PropModule1x1 board for my Plunge logger. Full size SD will plug straight into my laptop and I have a ton of the full size cards.
PARALLAX: There is a typo in the documentation PDF. Page 3, "Connecting and Testing" section states:
....to FAT formatted micro-SD cards with this adapter....
The "micro" should be removed, however a statement could be added that says "micro-SD cards can be used with a standard uSD-SD adapters sold with many uSD cards"
Thanks for the dimensions on page 4, that's excellent. One question: Are the mounting holes 1.4" apart on both directions? Only the vertical length has a dimension line.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
    WBA, thanks for the feedback...these issues will be revised and released early next week. Our editor is out until then or I would have it done sooner.
    Chris Savage
    Parallax Engineering
    50 72 6F 6A 65 63 74 20 53 69 74 65
