lm35 with long cable
I want to measure 2 temperature's points in bus(car), I think:
- Use about 30foot of twisted pair cable, adc0844 and a Propeller.
- Run this adc0844 in differential mode
But I think that I will have problems with noise.
Please can you recomend a circuit for this case or what can i do for reduced the noise?
how about changing to a digital temperature-sensor like the lm75 ?
Do you know what all your nerves inside your body do ?
They convert analog signals like temparature or pressure to DIGITAL values frequency-coded
If nature has evoluted to this solution practising it for 2.000.000.000 years it has to be a very good solution
best regards
Stefan
