SX Clock/alarm clock
I have started to work on·my clock·and hit a problem. I want to blank the first digit when the digit is not in use.
I have included my code with the post as well.
Thank you
ACE227
Post Edited (ACE227) : 10/9/2009 2:07:36 AM GMT
Thank you
ACE227
' Display timer in MM.SS (00.00 .. 59.59) format with solid DP SUB CLOCK_MMSS ' display mins & secs tmpB1 = mins / 10 ' get 10's digit tmpB2 = __REMAINDER ' save 1's digit READ SegMap + tmpB1, display(3) READ SegMap + tmpB2, display(2) display(2) = display(2) | DecPnt ' add DP to hr01 digit tmpB1 = secs / 10 tmpB2 = __REMAINDER READ SegMap + tmpB1, display(1) READ SegMap + tmpB2, display(0) [b]IF display(0) = %00111111 THEN ' if 1st digit is a 0 then blank display(0) = %00000000[b] ENDIF[/b][/b] HIGH LED PAUSE 500 LOW LED PAUSE 500 IF TmrEnable = TmrRun THEN GOTO Main ELSE ChangeSec ENDIF ENDSUB ' ------------------------------------------------------------------------- ' Display timer in HH.MM (00.00 .. 23.59) format with blinking DP CLOCK_HHMM: ' display hours & mins tmpB1 = hrs / 10 tmpB2 = __REMAINDER READ SegMap + tmpB1, display(3) READ SegMap + tmpB2, display(2) IF blink = Yes THEN display(2) = display(2) | DecPnt ' blink DP on hr01 digit ENDIF tmpB1 = mins / 10 tmpB2 = __REMAINDER READ SegMap + tmpB1, display(1) READ SegMap + tmpB2, display(0) [b] IF display(0) = %00111111 THEN ' if 1st digit is a 0 then blank display(0) = %00000000[/b] [b] ENDIF[/b] HIGH LED PAUSE 500 LOW LED PAUSE 500 IF TmrEnable = TmrRun THEN GOTO Main ELSE ChangeMin ENDIF ENDSUB▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
I got it to work on my circut board and I put in two leds. I want to blink one led once every second and the other led to blink once every ten seconds. Now I had the led for ever second to blink but the code would wait until it read through the code before continuing to the next step. I would like to know how to put in that bit of code and always run but not interupt the other coding.
Thanks for all the help.
ACE227
If you add a subject to your message, you'll be helping people who have your exact problem. Your solution can help them, but not if they can't find the posting.
Shawn Lowe
When all else fails.....procrastinate!
