Modbus-interface with Prop handling serious CNC-iron
Hi!
I simply can't find my initial posting about the Modbus-interface I've built around the Propeller. So here we go again ...
I have bought a CNC-mill, a MAHO 700-C with a broken control (Philips 432). With about 3 metric tonnes, it can be called some serious iron.
My intent was to replace the control with EMC2.
Electronics were mostly from MESA. A 5i20-card, and a 7i33.
I added my homebrew Modus-interface that does handle all the INs and OUTs (drive relays and read switches), added isolating-amps to drive the servo-amps, added opto-couplers for the glass-scales.
I had to replace some bearings and to repair the servo for the Z-axis (vertical axis). That servo alone has about 4kW and weights 82 kg. I had to remove it three times and fit in again until everything was sorted out.
Anyhow, she's moving! Made my first complete homing-sequence yesterday: www.youtube.com/watch?v=hVHv3uXByrc
Some things left to be done like switching gears and interfacing the handwheel, extending it for 5 axis, ...
But basically, I could mill!
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Post Edited (Nick Mueller) : 10/3/2009 8:56:42 AM GMT
Nick
YADRO
Reading the position of the gearbox and switching on/off the two motors that move the gears. The direction of rotation of the two motors (that look like Bosch-screen-whiper motors) is controlled by an extra relais. The spindle-amp is disabled by yet another output of the Modbus. Before gears are switched, the interface waits for the spindle to come to an stop.
www.youtube.com/watch?v=E0rVbVixMw8
Next time CHIPS! (but silicon-free
Nick
YADRO
Haha! The one hammering things straight again will be me.
I'll add an automatic tool-changer much later. Not something a Propeller MUST do, but I guess a Propeller WILL do. I think it will be a autark sub-system that will have to drive some steppers and read switches. But the tool-changer won't happen this year.
I'll add the hydraulic tool-clamping switches and logic today. Hope I get that running and don't discover new places that need repair. :-/
EMC2 is really great. Easy to use out of the box. And if you want to add extras, you have all the sources and a lot of hooks to connect your specific software to. But sometimes a pain to get the right information how to do things.
I'll keep you informed...
Nick
YADRO
Got a new old shaper today. Quite impressive, but there are larger ones.
www.youtube.com/watch?v=psUZmMxY3-s
Back to the MAHO fixing the gearbox on Monday ...
Nick
YADRO
