Pause problems
I have a problem that I do not know how to fix.
My program has a main routine and two Sub routine. The problem is that the sub routine need to stop for 2 minutes in order to do the task, opening a ventilation hatch.
My sub:
Alarm :
IF ((tc/10)<AlarmTmp) THEN
HIGH Closeled ' Close hatch
PAUSE Motortm ' Time to run motor
LOW Closeled ' Stop motor
ENDIF
The problem is that this sub is checking for user input, system set up.
In side Main:
GOSUB Get_165
IF switches.BIT7 = 1 THEN GOSUB menu
But is sub Alarm is pausing for 2 minutes when the user cannot enter the system menu by pressing the button they will need to wait two minutes.
My first ide was to change Alarm to:
Alarm :
DO WHILE cycleTm < motorTm
cycleTm = cycleTm + 1
GOSUB Get_165
LOOP
ENDIF
But for some strange reason did it not work! Can anybody clear this up for me?
B
My sub:
Alarm :
ENDIF
In side Main:
GOSUB Get_165
Alarm :
GOSUB Get_165
LOOP
ENDIF
B
This might work better.
Counter VAR Word Main: GOSUB Get_165 IF switches.BIT7 = 1 THEN GOSUB menu GOSUB Alarm GOTO Main Alarm: IF ((tc/10)<AlarmTmp) THEN ' Alarm triggered HIGH Closeled ' Close hatch FOR Counter = 1 TO 12000 ' You might lower this a little bit to account for processing time GOSUB Get_165 IF switches.BIT7 = 1 THEN GOSUB menu PAUSE 10 ' Pause 10 milliseconds NEXT LOW Closeled ' Stop motor ENDIF RETURN▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Don't worry. Be happy
Post Edited (dev/null) : 10/8/2009 6:10:30 AM GMT
