Propelelr Fast Serial comunication
Hi all.
Somebody last days talk about a fast serial comunication between propellers, but I can't remember neither found that thread.
Any ideas if there exist an object for that purpose ? I should to comunicate two pchips with no more than three pins each at high speed as possible.
I'm talking about much more than 115Kbps.
Regards.
Alberto.
Regards.
Alberto.
But I have plenty of objects that routinely handle 1Mb/sec without imposing upon timing too much. What distance are you talking about anyway?
*Peter*
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
Cheers,
Simon
www.norfolkhelicopterclub.com
Announcement: To cut costs in the current economic climate, we have switched-off the light at the end of the tunnel.
@Peter, it is only about two inches max, with the 10Mbps, do you mean the Simon and Cluso talk about ?
That's pretty enough !!
Regards.
Alberto.
''********************************************* ''* Fast Prop-Prop Comm v0.1 Alpha * ''* Sends information quickly between Props * ''* Author: Brandon Nimon * ''* Created: 16 September, 2009 * ''*********************************************************************************** ''* Requires pull-down on communication line. * ''* Prop1──┳──Prop2 * ''* 10K * ''*  * ''* The difference in clock speed between the two Propellers cannot excede 0.5%. * ''* Transfers information at 2 instructions per bit (8 cycles). * ''*********************************************************************************** ' 5.56us for 32 bits = normally 7.2M baud ' throughput of 711KB/s CON { ==[noparse][[/noparse] CLOCK SET ]== } _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 ' 5MHz Crystal BUFFER_SIZE = 256 ' longs to send and recieve (always sends all longs) OBJ DEBUG : "FullDuplexSerial" VAR long txbuffer[noparse][[/noparse]BUFFER_SIZE] long rxbuffer[noparse][[/noparse]BUFFER_SIZE+4] long rxvalue[noparse][[/noparse]BUFFER_SIZE] PUB Main | loc, i '' sets up for single-propeller testing DEBUG.start(31, 30, 0, 115200*8) waitcnt(clkfreq + cnt) DEBUG.tx($0D) longfill(@txbuffer, 0, BUFFER_SIZE) ' clear output (not necisary now that I am filling it below) longfill(@txbuffer[noparse][[/noparse]6], 21845, BUFFER_SIZE) ' fill rest of buffer with _a_ number txbuffer[noparse][[/noparse]0] := $55555555 ' just some test data txbuffer := 2345 txbuffer := 34567 txbuffer := 456789 txbuffer := 5678901 txbuffer := 67890123 txbuffer[noparse][[/noparse]BUFFER_SIZE-1] := 987654321 recieve(1) ' recieve on pin 27 send(0) ' send on pin 26 REPEAT waitrx ' wait for input REPEAT i fROM 0 TO constant(BUFFER_SIZE - 1) DEBUG.tx($0d) debug.dec(i) debug.tx(",") DEBUG.dec(rxvalue[i]) ' display all longs of rx DEBUG.tx($0d) PUB send (pin) txpin := pin cognew(@tx_entry, @txbuffer) PUB recieve (pin) longfill(@rxbuffer, 0, BUFFER_SIZE) ' clear data (just in case) rxmask := |< pin cognew(@rx_entry, @rxbuffer) PUB waitrx REPEAT UNTIL rxbuffer ' wait until _something_ is put into the first long of the buffer waitcnt(constant((12 * 32 + 20) * (BUFFER_SIZE - 1)) + cnt) ' wait for rest of info to be transfered @12 cycles per bit longmove(@rxvalue, @rxbuffer, BUFFER_SIZE) ' I would like to get rid of this longfill(@rxbuffer, 0, BUFFER_SIZE) ' clear for next use (again, I will find a way to remove this) RETURN @rxvalue ' not used, but will be needed once it is an object DAT ORG 0 tx_entry MOV txmask, #1 SHL txmask, txpin ' setup mask MOV CTRA, nco ADD CTRA, txpin ' NCO on this pin number MOV DIRA, txmask ' set pin as outpu tx_bloop MOV txptr, PAR ' get input buffer address MOV txbidx, #buffer_size ' set for 32 longs tx_loop RDLONG txval, txptr ' get current output long MOV txidx, #32 ' set for 32 bits (a long) MOV PHSA, negone ' send a one-instruction pulse MOV PHSA, txval ' setup NCO output txbloop 'NOP ' to sync with RX loop. this can be removed when RX DJNZ is replaced with many instructions SHL PHSA, #1 ' set next bit DJNZ txidx, #txbloop MOV PHSA, #0 ' make sure 0 output MOV time, cnt ADD time, wait WAITCNT time, #0 ' wait for RX loop ADD txptr, #4 ' move read pointer one long DJNZ txbidx, #tx_loop ' do next long until done with buffer MOV time, cnt ADD time, wait2 WAITCNT time, #0 ' wait for RX to be ready again JMP #tx_bloop wait LONG 20 ' this will end up being slightly faster wait2 LONG 80000 ' this too will end up being faster negone LONG -1 nco LONG %00100 << 26 txpin LONG 0 ' set in SPIN txval RES txmask RES time RES txidx RES txbidx RES txptr RES FIT 496 '======================================================= ' ORG 0 rx_entry OR dira,synch andn outa,synch MOV rxptr, PAR ' get output buffer address MOV rxbidx, #buffer_size rx_loop MOV rxidx, #32 ' set for 32 bits (a long) MOV rxval, #0 ' clear current long WAITPEQ rxmask, rxmask ' wait for high pulse from TX :loop TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value TEST rxmask, INA WC ' get INA mask RCL rxval, #1 ' set value ' DJNZ rxidx, #:loop ' will be removed and replaced with 32 test/rcl for speed purposes XOR outa,synch WRLONG rxval, rxptr ' write current long to buffer ADD rxptr, #4 ' move write pointer one long DJNZ rxbidx, #rx_loop ' do next long until done with buffer JMP #rx_entry rxmask LONG 0 ' set in SPIN synch LONG 4 rxval RES rxptr RES rxidx RES rxbidx RES FIT 496 [/i]▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
*Peter*
http://forums.parallax.com/showthread.php?p=841367
*Peter*
That's what I was looking for, & yes, search.parallax gives me a headache last night searching.... [noparse]:([/noparse]
Regards.
Alberto.
