Buffer Mania
Peter,
This one is VERY STRANGE.
I am trying to create a list of transactions
static List scanLog = new List(100);
static StringBuffer myBuffer = new StringBuffer();··
1. First I use a string buffer to create a transaction string
···then add this string to a list
myBuffer.clear();
myBuffer.append("@");
myBuffer.append("123");
scanLog.add(0,myBuffer.toString());·
2. Now I clear myBuffer, Create a second string and store
··· the next string in the list as a new index
myBuffer.clear();
myBuffer.append("456");
scanLog.add(1,myBuffer.toString());·
3. Now I look at whats in the list by index
System.out.println((String)scanLog.get(0));
System.out.println((String)scanLog.get(1));
This reports:
@456
@456
It some how holds a reference to last myBuffer string
and doesn't hold the correct strings in the List. Bizzare.
The Strange part is when I do not use a stringbuffer
it seems to work:
String str = "@123"
scanLog.add(0,str);
str = "@456"
scanLog.add(1,str);
Now I get:
@123
@456
My problem is I need to use a stringbuffer to
assemble my strings for memory efficiency.
What don't I get about these stupid stringbuffers
I am clearing it and it still won't work properly.
PLEASE HELP!
PS: Even when I create a string array -vs- string buffer
I get the same result when I set it equal to a string buffer
I am reusing with myBuffer.clear(); (I've also tried myBuffer.delete(0,4))
Jeff(trytryagain)
myBuffer.clear();
myBuffer.clear();
This reports:
@456
@456
it seems to work:
String str = "@123"
scanLog.add(0,str);
str = "@456"
scanLog.add(1,str);
Now I get:
@123
@456
PLEASE HELP!
Jeff(trytryagain)
Applying toString merely returns the reference to this one array, but as type String.
So
myBuffer.clear();
myBuffer.clear();
This reports:
@456
@456
makes perfect sense as you store the references, not the content of the array.
When using Strings,
String str = "@123"
scanLog.add(0,str);
str = "@456"
scanLog.add(1,str);
Now I get:
@123
@456
str gets the reference of the constant strings and those references are different,
and thus you store different references. and thus reading back shows different content.
What you need to do is to store the content of the StringBuffer in a new StringBuffer,
and store the reference of this new StringBuffer.
regards peter
Can I create an array of 100 string buffers
each with a max length of 30
up front so I know my memory allocation.
If so, could you do me big favor and show me
the proper declaration for the string buffer array
and change my supplied code as an example.
I have·been working on this for over 6 hours.
Thanks as always Pete,
Jeff
regards peter
I initialized the buffer per your example:
static StringBuffer sArray[noparse]/noparse = new StringBuffer[noparse][[/noparse]100];
· static {
··· for (int i=0; i<100; i++) {
····· sArray[noparse][[/noparse]i] = new StringBuffer(30);
myBuffer.clear();
int scanIndex = 0;
scanIndex++;
sArray[noparse][[/noparse]scanIndex] = myBuffer;
myBuffer.clear();
scanIndex++;
I am still getting the same values for
sArray[noparse][[/noparse]1] = @456
sArray[noparse][[/noparse]2] = @456
I am using a different index of the sArray buffer
each time and Its still happening!
Jeff
· static {
int scanIndex = 0;
sArray[noparse][[/noparse]scanIndex].clear();
sArray[noparse][[/noparse]scanIndex].append("@");
sArray[noparse][[/noparse]scanIndex].append("123");
scanIndex++;
sArray[noparse][[/noparse]scanIndex].append("456");
scanIndex++;
etc.
Better to create a method clear and append
static void clear(int i) {
· sArray[noparse][[/noparse]i].clear();
static void append(int i, String s) {
· sArray[noparse][[/noparse]i].append(s);
and call these methods
regards peter
Does that work because the reference is coming from a function?
Jeff
change the index.
The nice thing about a OOP language like java is
that you can call a method via the variable.
sArray[noparse][[/noparse]i] is the variable (of type StringBuffer in this case), append(s) is the method.
And that also allows it to be embedded in another method.
regards peter
After all this I have really grown to dislike strings
These references backword certainly save on space
but make it frustrating to use strings in logs.
Luckily all the values in my string are integers
so I made arrays out of each piece:
index++
Month[noparse][[/noparse]index] = 9
Day[noparse][[/noparse]index] = 14
Year[noparse][[/noparse]index] = 2009
index++
Month[noparse][[/noparse]index] = 10
Day[noparse][[/noparse]index] = 25
With integers the values stick.
I assemble the same buffer each time I send a different index of data
buff.clear();
int indextosend = 0;
buff.append(Month[noparse][[/noparse]indextosend]);
buff.append(Day[noparse][[/noparse]indextosend]);
buff.append(Year[noparse][[/noparse]indextosend]);
I will try your suggestion as well Pete
Thanks so much for the explanation
I hope in future versions of Javelin they
give us a little more memory and a better
method to work with strings.
Jeff(trytryagain)
check out my Calendar class. It provides methods
to convert between binary stored dates and times
and human readable strings.
regards peter
I appreciate the·calendar code.
Thanks so much for all your help today.
Jeff
