Modified Easy Bluetooth code — Parallax Forums
NWUpgradesNWUpgrades Posts: 293
edited 2009-10-03 23:20 in BASIC Stamp
Does anyone have a modified version of EasybluetoothPBASIC.bs2 that will work on the BS2sx chip? I have been beating my brains out for 2 days trynig to modify it to get it to work and can not seem to nail it down. Thanks for any help.
  • hover1hover1 Posts: 1,929
    edited 2009-10-03 21:35
    NWUpgrades said...
    Is the directive set to: ' {$STAMP BS2sx}· ?
    Did you change the baud rate to match the BS2sx chip?
    I haven't downloaded the .bs2 program in question but I can do that later.
    Jim
    edited 2009-10-03 21:43
    #case bs2sx, bs2p
    t1200 con 2063
    t2400 con 1021
    t4800 con 500
    t9600 con 240
    t19k2 con 110
    t38k4 con 45
    edited 2009-10-03 21:51
    Found in the BS2 Help File--SERIN
    Interesting Note:
    Baud Rate 8-bit No Parity INVERTED 8-bit No Parity TRUE 7-bit Even Parity INVERTED 7-bit Even Parity TRUE
    4800 * 17197 813 25389 9005
    9600 * 16780 396 24972 8588
    * The BASIC Stamp 2sx and BASIC Stamp 2p may have trouble synchronizing with the incoming serial stream at this rate and higher due to the lack of a hardware input buffer. Use only simple variables and no formatters to try to solve this problem.
  • NWUpgradesNWUpgrades Posts: 293
    edited 2009-10-03 22:37
    Yes, I have done all this. The baud is set to CON 240 and I am able to connect using the Boe Bot Remote Control software, but after it connects I am unable to make the servos turn.
    edited 2009-10-03 22:50
    NWUpgrades said...
    I figured you had all the basic stuff covered. How about a peek at the code? May help.
    Jim
    Here it is. Note that the original buffer3 and buffer4 values are 100 and the Set_Servo_Speed values were 650. However, it did not work like that so I multiplied by 2.5 but it still does not work. I can get the connection, but no movement.
    '·· File...... Easy Bluetooth.bs2
    '·· Purpose... Control a Boe-Bot with a GUI interface
    '·· Author.... Technical Support & RoboTech SRL
    '·· E-mail.... support@parallax.com
    '·· Started... April 1st 2009
    '·· Updated... N/A
    '·· {$STAMP BS2sx}
    '·· {$PBASIC 2.5}
    [noparse][[/noparse] Program Description ]
    ' This program is what is loaded into the BASIC Stamp prior to using the GUI interface
    ' from RoboTech SLR. It allows a Boe-Bot to be controlled via a GUI interface.
    ' Commands are as followed:
    '···· Up Arrow··· = Forward
    '···· Down Arrow· = Backwards
    '···· Left Arrow· = Left Turn
    '···· Right Arrow = Right Turn
    '···· Space Bar·· = Stop
    ' You can press and hold and release an arrow key for 2 seconds to access a double speed
    ' of each action. For example, Press Up Arrow, release to make the Boe-Bot move faster
    ' forward.
    [noparse][[/noparse] I/O Definitions ]
    BT_RX········· PIN···· 2···················· ' RX of the Easy Bluetooth
    BT_TX········· PIN···· 0···················· ' TX of the Easy Bluetooth
    LED··········· PIN···· 5···················· ' Indicator LED for Bluetooth Connection
    [noparse][[/noparse] Constants ]
    BT_SPEED······ CON···· 240··················· ' baud 9600 true UART
    [noparse][[/noparse] Variables ]
    tLeft········· VAR···· Word················· ' Left Servo control pulse durations
    tRight········ VAR···· Word················· ' Right Servo control pulse durations
    temp·········· VAR···· Word················· ' Temp variable
    ' Buffer array not declared as buffer VAR Word(5) for SERIN functionality.
    ' It can still be accessed as buffer(0), buffer(1), etc.· However,
    ' buffer0, buffer1, etc. should be used in SERIN commands with variations
    ' of WAIT.
    · buffer0······· VAR···· Byte················· ' Buffer - Start char = $ff
    · buffer1······· VAR···· Byte················· ' Message Index value
    · buffer2······· VAR···· Byte················· ' Command
    · buffer3······· VAR···· Byte················· ' Argument 1 (return data 1)
    · buffer4······· VAR···· Byte················· ' Argument 2 (return data 2)
    · buffer········ VAR···· buffer0·············· ' For standard array indexing
    · msgIndex······ VAR···· Byte················· ' message index
    · rxc··········· VAR···· Byte················· ' Receive Clear
    [noparse][[/noparse] Initialization ]
    Program_Start:
    · LOW LED
    · DEBUG CLS
    · PAUSE 1000······················································ ' Wait for the RBT-001 radio to be ready.
    · msgIndex = 0
    · buffer0 = $FF··················································· ' Connection packet
    · buffer1 = msgIndex
    · buffer2 = $CC
    · buffer3 = 250
    · buffer4 = 250
    · GOSUB Set_Servo_Speed
    · DEBUG CR,"Waiting connection..."································ ' wait for connection request
    · SERIN BT_RX, BT_SPEED, [noparse][[/noparse]WAITSTR buffer \ 3, buffer3, buffer4]··· '
    [noparse][[/noparse] Program Code ]
    DO
    · SELECT buffer2
    · CASE $CC························································ ' Connect
    ··· HIGH LED
    ··· msgIndex = 0
    ··· DEBUG CR,"Connected"
    ··· GOSUB Reply
    · CASE $DD························································ ' Disconnect
    ··· LOW LED
    ··· DEBUG CR,"Disconnected"
    ··· GOSUB Reply
    ··· GOTO Program_Start
    · CASE $11························································ ' Servo
    ··· DEBUG CR,"Servo"
    ··· GOSUB Set_Servo_Speed
    ··· GOSUB Reply
    · CASE ELSE······················································· ' Error
    ··· buffer2 = $EE
    ··· GOSUB Reply
    · ENDSELECT
    ·Resume:·························································· ' If Message not rcvd, try again
    ·PULSOUT 13, tLeft················································ ' Servo control pulses
    ·PULSOUT 12, tRight
    ·SERIN BT_RX, BT_SPEED, 10, Resume,······························· ' Get next command
    ····· [noparse][[/noparse]WAITSTR buffer \ 2, buffer2,
    ····· buffer3, buffer4]
    ·PULSOUT 13, tLeft················································ ' Servo control pulses again
    ·PULSOUT 12, tRight
    LOOP
    Reply:
    · msgIndex = msgIndex + 1········································· ' Increment message index for reply.· Next message from PC has to use
    · buffer1 = msgIndex·············································· ' reply's buf[noparse][[/noparse]1].
    · SEROUT BT_TX, BT_SPEED, [noparse][[/noparse]STR buffer \5]
    [noparse][[/noparse] Subroutines ]
    Set_Servo_Speed:·················································· ' Range of 0 to 200 with 100 = stopped maps to 650 to 850 with 750 stopped.
    · tLeft = buffer3 + 1625··········································· ' Decode servo speed.
    · tRight = buffer4 + 1625
    RETURN
    [noparse][[/noparse] Data ]
    ResetOnOff········· DATA 0········································ ' On/off toggle w/ Reset button
    RequestConnect····· DATA $FF, 0, 1, 0, 0
    ConnectionGranted·· DATA $FF, 0, 2, 0, 0
    RequestCommand····· DATA $FF, 0, 3, 0, 0
    ServoSpeeds········ DATA $FF, 0, 4, 0, 0
