Robotic Leg Blue Tooth Issue — Parallax Forums
NWUpgradesNWUpgrades Posts: 293
edited 2009-10-03 15:55 in BASIC Stamp
OK. Using a BS2 chip· and the following code along with the BoeBot Remote Control program, I am able to connect and control my servos on a BOE board. However, When I connect my BS2sx chip, I am able to connect, but none of the arrows work to control the servos. I modified the program to Con 240, multiplied the buffer by 2.5 and also the Servo Speed by 2.5. What I am missing that is not letting my BS2sx chip work like the BS2 chip does?
·File...... Easy Bluetooth.bs2
'·· Purpose... Control a Boe-Bot with a GUI interface
'·· Author.... Technical Support & RoboTech SRL
'·· E-mail.... support@parallax.com
'·· Started... April 1st 2009
'·· Updated... N/A
'·· {$STAMP BS2sx}
'·· {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program is what is loaded into the BASIC Stamp prior to using the GUI interface
' from RoboTech SLR. It allows a Boe-Bot to be controlled via a GUI interface.
' Commands are as followed:
'···· Up Arrow··· = Forward
'···· Down Arrow· = Backwards
'···· Left Arrow· = Left Turn
'···· Right Arrow = Right Turn
'···· Space Bar·· = Stop
' You can press and hold and release an arrow key for 2 seconds to access a double speed
' of each action. For example, Press Up Arrow, release to make the Boe-Bot move faster
' forward.
[noparse][[/noparse] I/O Definitions ]
BT_RX········· PIN···· 2···················· ' RX of the Easy Bluetooth
BT_TX········· PIN···· 0···················· ' TX of the Easy Bluetooth
LED··········· PIN···· 5···················· ' Indicator LED for Bluetooth Connection
[noparse][[/noparse] Constants ]
BT_SPEED······ CON···· 240·················· ' baud 9600 true UART
[noparse][[/noparse] Variables ]
tLeft········· VAR···· Word················· ' Left Servo control pulse durations
tRight········ VAR···· Word················· ' Right Servo control pulse durations
temp·········· VAR···· Word················· ' Temp variable
' Buffer array not declared as buffer VAR Word(5) for SERIN functionality.
' It can still be accessed as buffer(0), buffer(1), etc.· However,
' buffer0, buffer1, etc. should be used in SERIN commands with variations
' of WAIT.
· buffer0······· VAR···· Byte················· ' Buffer - Start char = $ff
· buffer1······· VAR···· Byte················· ' Message Index value
· buffer2······· VAR···· Byte················· ' Command
· buffer3······· VAR···· Byte················· ' Argument 1 (return data 1)
· buffer4······· VAR···· Byte················· ' Argument 2 (return data 2)
· buffer········ VAR···· buffer0·············· ' For standard array indexing
· msgIndex······ VAR···· Byte················· ' message index
· rxc··········· VAR···· Byte················· ' Receive Clear
[noparse][[/noparse] Initialization ]
Program_Start:
· LOW LED
· DEBUG CLS
· PAUSE 1000······················································ ' Wait for the RBT-001 radio to be ready.
· msgIndex = 0
· buffer0 = $FF··················································· ' Connection packet
· buffer1 = msgIndex
· buffer2 = $CC
· buffer3 = 250
· buffer4 = 250
· GOSUB Set_Servo_Speed
· DEBUG CR,"Waiting connection..."································ ' wait for connection request
· SERIN BT_RX, BT_SPEED, [noparse][[/noparse]WAITSTR buffer \ 3, buffer3, buffer4]··· '
[noparse][[/noparse] Program Code ]
DO
· SELECT buffer2
· CASE $CC························································ ' Connect
··· HIGH LED
··· msgIndex = 0
··· DEBUG CR,"Connected"
··· GOSUB Reply
· CASE $DD························································ ' Disconnect
··· LOW LED
··· DEBUG CR,"Disconnected"
··· GOSUB Reply
··· GOTO Program_Start
· CASE $11························································ ' Servo
··· DEBUG CR,"Servo"
··· GOSUB Set_Servo_Speed
··· GOSUB Reply
· CASE ELSE······················································· ' Error
··· buffer2 = $EE
··· GOSUB Reply
· ENDSELECT
·Resume:·························································· ' If Message not rcvd, try again
·PULSOUT 13, tLeft················································ ' Servo control pulses
·PULSOUT 12, tRight
·SERIN BT_RX, BT_SPEED, 10, Resume,······························· ' Get next command
····· [noparse][[/noparse]WAITSTR buffer \ 2, buffer2,
····· buffer3, buffer4]
·PULSOUT 13, tLeft················································ ' Servo control pulses again
·PULSOUT 12, tRight
LOOP
Reply:
· msgIndex = msgIndex + 1········································· ' Increment message index for reply.· Next message from PC has to use
· buffer1 = msgIndex·············································· ' reply's buf[noparse][[/noparse]1].
· SEROUT BT_TX, BT_SPEED, [noparse][[/noparse]STR buffer \5]
[noparse][[/noparse] Subroutines ]
Set_Servo_Speed:·················································· ' Range of 0 to 200 with 100 = stopped maps to 650 to 850 with 750 stopped.
· tLeft = buffer3 + 1625··········································· ' Decode servo speed.
· tRight = buffer4 + 1625
RETURN
[noparse][[/noparse] Data ]
ResetOnOff········· DATA 0········································ ' On/off toggle w/ Reset button
RequestConnect····· DATA $FF, 0, 1, 0, 0
ConnectionGranted·· DATA $FF, 0, 2, 0, 0
RequestCommand····· DATA $FF, 0, 3, 0, 0
ServoSpeeds········ DATA $FF, 0, 4, 0, 0
Post Edited (NWUpgrades) : 10/2/2009 8:41:03 PM GMT
  • vanmunchvanmunch Posts: 568
    edited 2009-10-03 14:26
    I think you need to change your:
    "BT_SPEED CON 240 ' baud 9600 true UART"
    from 240 to 990 (396 x 2.5), but I'm not sure. I was having a similar problem with getting my new BS2sx to work with the the new propeller servo controllers. I changed the baud Con from 396 to 990 and it works now. Below is the modified code. I hope it works for you too.
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    'hipAngles.bs2 .Simple code to try out differant servo postions
    'hip VAR Byte
    'knee VAR Byte
    'foot VAR Byte
    leg VAR Byte
    pw VAR Word
    ra VAR Byte
    sdat CON 15
    baud CON 990 'mutltiplied 396 by 2.5 for the BS2sx which is 2.5X faster than BS2
    LFhip CON 5 'Left Front hip
    LFknee CON 6
    LFfoot CON 7
    LRhip CON 8 'Left Rear hip
    LRknee CON 9
    LRfoot CON 10
    RFhip CON 0 'Fight Front hip
    RFknee CON 1
    RFfoot CON 2
    RRhip CON 13 'Right Rear hip
    RRknee CON 14
    RRfoot CON 15
    LPawHip CON 24 'Left Paw hip
    LPawKnee CON 25
    LPawFoot CON 26
    RpawHip CON 29 'Right Paw hip
    RPawKnee CON 30
    RPawFoot CON 31
    DO
    GOSUB Front_Left
    LOOP
    '---Subroutine
    Front_Left:
    ra = 9
    DO
    'Rotate hip tword each other
    DEBUG CR, "hips moving!"
    pw = 900
    SEROUT Sdat, Baud+$8000, [noparse][[/noparse]"!SC", RpawHip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    'PAUSE 1000
    pw = 1200
    SEROUT sdat, baud+$8000,[noparse][[/noparse]"!SC", Rfhip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    pw = 600
    SEROUT sdat, baud+$8000,[noparse][[/noparse]"!SC", Rrhip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    pw = 600
    SEROUT sdat, baud+$8000,[noparse][[/noparse]"!SC", LpawHip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    pw = 1200
    SEROUT sdat, baud+$8000,[noparse][[/noparse]"!SC", Lfhip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    pw = 900
    SEROUT sdat, baud+$8000,[noparse][[/noparse]"!SC", Lrhip, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
    PAUSE 1000
    LOOP
    RETURN
  • NWUpgradesNWUpgrades Posts: 293
    This did not work. I can no longer even get a connection. Everything I have read points to baud needing to be CON 240 for 9600. I am able to connect and it will bring up the up, down, left and right arrows, but there is no control of them. I do not see in your code where I would actually have the RX and TX connection.
