Digital Photoframe with Prop?
Hi folks,
does anyone know a program for Prop which loads several images from an SD-Card and displays it on some kind of LCD-Display?
I don't need transitions or stuff like that..
Just: Load image 1, display it for a certain time, Load image 2, display it for a certain time, etc.
Thank you!
Thank you!
Check out my PSM:
http://www.rayslogic.com/Propeller/Products/PSM/PSM.htm
There's a slideshow app already for it you can download...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
http://www.rayslogic.com/propeller/Programming/RaysStuff/JuiceBox/JuiceBox.htm
Is it possible to add a real time clock and some LEDs to it?
Thank you!
http://gadgetgangster.com/
It's relatively easy to external devices as there are 8 free pins brought out on a header.
Also, the I2C bus is on a header.
I have a completed design for a board that connects to the PSM (called PAB), and gives
RTC amongst other things.· I still hope to bring that to market soon, but right now I'm
devoting my $$ and time to developing the PSB (a new, larger board with touchscreen).
Is there a limitation of Photos? What's the maximum size of SD-Card i can insert?
Ah and antoher question: is it possible to run music from the SD-Card?
Thank you very much!
When i insert it, it says "Mounting" but stays like this without changing. Even when i remove the card, it doesn't change at all.
I can't see a Slideshow!
Could it be a problem because i use a MicroSD-Card in an SD-Card-Adapter?
Thank you,
Max
I need to either switch that code to the new FSRW or try to mount a couple times in the code before giving up...
The type of card probably doesn't have anything to do with it...
Could it be a problem with the file-system on the card or the files on the card?
Thank you for your help!
Max
[noparse]:edit:[/noparse] just realized that the image hast 24bit (windows says that). Actually i trid to save it with 8bit via Photohsop :? Not sure what it is now....
How can i make it work without starting the propeller twice again?
(At least that's my theory).
I'm hoping that just switching to FRSW 2.4 cures the issue...
That should also make the photos appear much faster...
Or, in most of my codes I try several times to "mount" before giving up...
I need to check that this one is doing this...
Now i try to get the waveplayer44 working, but nothing happens at all...
i've got an .wav-file on the card (~8MB), nothing appears on the screen or in the earphones...
I want to update all my codes to this one...
The wav player on my website for the PSM should work...
Make sure you change the filename in the code to match yours.
Long filenames are not supported and it must be in the root directory...
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
