using the prop chip to measure capacitors
Guys I tried to search for this I remember a while back some had built a circuit using a prop chip to measure capacitors? I bought a bag of misc capacitors 500 to be exact they are all disk caps of different values I do not have a capacitor meter but was hoping
a simple circuit using the prop chip was available. I found "PE Kit Tools - Measure Resistance and Capacitance v0.92" But its not quite what I had in mind. I was hoping a simple meter could be built out of the prop and a serial LCD display
if anyone remembers where that project was or if you have something similar you can share please let me know Thank you.
You could setup a similar circuit using two RCTIME circuits and comparing the returned value to a known capacitor verses an unknown capacitor, however the advantage of the circuit below compared to an RCTIME circuit is that the value of the resistors used aren't as critical as the ratio of the resistors used, making a digital POT an ideal candidate.
Beau Schwabe
IC Layout Engineer
www.amqrp.org/kits/elsie/
I designed a PCB for it and built my own version.
A Propeller could be substituted for the AVR, of course.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
· -- Carl, nn5i@arrl.net
agfa
Leon
