usless box
I want to build something like this.· But different.
http://www.youtube.com/watch?v=7bE7U0fHtQ8&feature=player_embedded
I dont really want to use a stamp and a couple of servos, I want it to be cheap. ·I think I can get the motion I want with a relay, two switches and two DC motors.
But I need some gearboxes to put on the motors.
So my question for you guys is, where can I get some small 3 Volt DC motors with a large gear reduction.
Like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHA26&P=ML
but cheap.
I figure you guys are my best bet for knowledge about cheap and small DC motors.
Post Edited (zaphoid) : 9/29/2009 1:04:12 AM GMT
Like this:
but cheap.
My general plan is to use a cigar box, not a see through box. There would be no second arm to lift the lid. Because of the cigar box shape, the switch would have to be on the front or side, not the top. I think the side is best. Picture an arm with the elbow at ninety degrees. A four bar link raises the arm above the top of the box and over top the switch. A hidden switch stops motor one and starts the shoulder motor, which rotates the arm down, hitting the switch. Another switch reverses power when the shoulder reaches the right travel limit.
My arm would be more like a doll baby arm. I also plan on holding the box shut, so no one can see whats inside (maybe have the bottom open for batteries once it all works perfectly).
Just a box, with a switch. Hit the switch and an arm pops out flips the switch back. No explanations nothing.
here is a video of one.
· -- Carl, nn5i@arrl.net
