A thought for handheld designers
Oldbitcollector (Jeff)
I was in the surplus store this weekend, (they carry scratch & dent, and old stock, etc)
and noticed a wall of small leather cases designed for PSP, etc.
(Found a 20-drawer parts cabinet for $3.00!)
I had a thought.. One of the hardest things that all of us have dealt with is finding
a source of cases for our Propeller projects. Why not adapt our designs to fit existing
popular designs?
It would be tricky, but lets say we created a board which fit the gameboy case and
took advantage of the button placement, etc. These can be purchased cheaply
from Ebay.
OBC
New to the Propeller?
popular designs?
from Ebay.
OBC
I agree with you 100%. This is something everyone (including Parallax
designs a Propeller PCB which fits the Gameboy. Bonus points for use of the
existing screen. [noparse]:)[/noparse]
OBC
http://hackaday.com/?s=gameboy
What do you think is the ideal size for an enclosure?
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
····www.lansing-enclosures.com/
Also, Parallax will soon be offering their own extruded housings for the MoBo line of products (and anything else that fits). Here's a teaser:
This particular project displays weather forecasts from Yahoo! Weather and receives data and power from an attached PC via the USB port.
Post Edited (Phil Pilgrim (PhiPi)) : 9/27/2009 8:08:03 PM GMT
I was going to use that same aluminum extrusion display box for my name tag at the next EXPO. My problem has been finding one with 12 Characters and an alpha-numeric version to display the "W" in my last name. -
Beau Schwabe
IC Layout Engineer
I remember seeing those gameboy housings and had the same idea.
But what do you do about a cheap LCD to go with it?
Ended up using another cheap pre-fabbed and roomy case [noparse]:)[/noparse]
The Sony PSP housing looks more attractive now with Rayman's LCD work.
--Steve
Propeller Tools
Also various PVC pipes, end caps and electric wiring cases at the hardware store could be used.
"Where am I? Where am I going? Why am I in a handbasket?"
The other one? Well ...
<Airplane II>
Striker: Which passenger is Joe Solucci?
Mary, Shuttle Stewardess: 16C. Why?
Striker: He's carrying a .....
Mary, Shuttle Stewardess: A bo - ?
Striker: No, not a bo-. A ..... Now, discreetly as possible, I want you to move the passengers, into the lounge.
Mary, Shuttle Stewardess: We don't, have a lounge.
Striker: That's not important right now but, you got to do is get those people away from that .....
Mary, Shuttle Stewardess: Well, what should I say?
Striker: Anything, don't let Solucci think, that we're getting onto him.
Mary, Shuttle Stewardess: I'll do my best.
</Airplane II>
--Steve
Propeller Tools
My father spent some time talking to the feds (friendly conversation, he's a plumber by trade.)
They interviewed every person who made those purchases when they were trying to
locate a pipe bomber a few years ago.
Amazing how the feds can get the records on pipe fittings when they want them. [noparse]:)[/noparse]
OBC
Steve Ciarcia (once of Byte fame, now with Circuit Cellar) had a similar problem that he relates in his editorials in CC.
I have a number of projects in those old black anti-static boxes that sample chips used to come in. A DIY logic probe wound up in a magic marker tube. The project boxes at Radio Shack seem to be at just that awkward size -- "no size fits one."
Then, there was the "Monster Detector" featured in Nuts & Volts a while back: the project went into a peanut butter jar!
--Rich
Your name isn't that awful in 7-segment form:
Okay the "W" is a little weird, but context is everthing, right?
Whit+
But seriously Phil if you want the things for the cases there yours
Thanks for the lansing link though. The E series is just what I was looking for enclosure-wise if a bit pricy. Now to figure out how I will cut the LCD opening......
Getting the circuit built is easy..... getting it in a box seems to be the hardest part [noparse];)[/noparse]
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Beau Schwabe
IC Layout Engineer
* Perfect for instrument or mobile data enclosures requiring a keypad and display.
* Available with either a solid display area (1592ETSD) or a versatile opening with a clear lens (1592ETCD).
* Molded from flame retardant ABS plastic, choice of black or grey (material carries a UL flammability rating of 94V-0).
* 1592ETSD offers a solid display area 122 mm x 85 mm (4.8" x 3.4") that will accommodate display boards up to 118 mm x 60 mm (4.6" x 2.37").
* 1592ETCD offers a clear polycarbonate lens 102 mm x 45 mm (4.0� x 1.77") and a plain mylar mask kit allowing for installation of a wide variety of display boards with the protection of the clear lens and dressed by the mylar frame.
* The lens fits snugly into the case and provides protection from dirt and dust.
* The back of the case has been designed to accept a magnetic strip or velcro mounting tab (see accessories).
* The display area has been insert tooled in order to provide the capability of custom molding a low-cost display area to specific requirements.
www.hammondmfg.com/dwg7.htm
I have another very small box that has a rectangular cutout on top for a rocker switch and three holes in one side for three 2 wire cables. The cost of the box and to have it machined was less than the cost of the box itself, once I ordered the first 250.
I also really like their VM series of handheld enclosures. Especially with the boots. A few minutes of modifying one, and the Parallax RFID reader fits inside the VM-24 for a handheld RFID unit. (I don't have any pictures of that)
I agree with OBC, that using an enclosure that fits a "readily-available" product's form factor will make other items adaptable (like carrying cases, etc). I am looking at using the Otterbox waterproof case for the IPOD nano for my plunge logger for example instead of trying to find another case.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
HM356-ND,· HM967-ND (Newark have it in a nice transparent blue 64M6634LTBU and Rapid 30-1849), HM964-ND (Newark T/blue 77M9535, Rapid 30-1851)
Sparkfun have an expensive one SFE-BOX.
Jaycar have a T/Blue box but you have to cut it.
Now, has anyone seen a matchbox sized box??? I want one for my ZiCog/CPM computer
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
www.polycase.com/item/lp-21p.html
Andrew Williams
WBA Consulting
If they don't need to change, for a name sign, just turn a "3" 90 degrees to make an M or W.
X is the hardest but if you clearly use H with lower case h then maybe get away with it.
I've used 7-segment alpha displays, but why not use dot-matrix LED's instead,
other than for nixie-tube like style. "E.T. phone home." The 1978 Buck Rogers series
used 7-segment alpha font on every sign on Earth. Probably because many single board
microcomputer kits had 16 keys and 8 digit seven segment displays then. Not sure, but
"KIM-1" sounds like one of those.
In the spirit of the original post.. (Sorry guys I can't drill, cut & label without my products looking very, very homemade.)
If you design a Propeller board which fits the GB (or similar mass produced casing) I'll bet Nick at GadgetGangster
would be happy to market them for you. GO FOT IT!
OBC
One of these maybe? http://www.hammondmfg.com/dwg9TBU.htm
James
