What have you done with your PSM? — Parallax Forums
blittledblittled Posts: 695
edited 2009-09-29 17:07 in Propeller 1
My friend and fellow forum member Jim Fouch recently bought a laser cutter table so I made plans for a "case" for my PSM. This is the end result of our creativity.
It is actually 3 platforms so I can increase the height of the platforms to accommodate various add ins. The top platform holds the PSM. The second platform holds a m100 keyboard which I drilled 3 holes in the case for mounting screws. Also I had a section cut out below the PSM so that there would be ample prototyping room. The lower platform has a breadboard and a battery holder. The breadboard has the connections to the keyboard and a DS1302 clock circuit. By the way as you can see by one the dates on the pictures I got this to work as a time machine smilewinkgrin.gif .
What electronics need - MORE POWER!!!!!!!
Post Edited (blittled) : 9/28/2009 1:00:59 AM GMT
  • RaymanRayman Posts: 15,964
    edited 2009-09-28 01:04
    Looks great! Nice job.
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • mikedivmikediv Posts: 825
    edited 2009-09-28 21:37
    blittled very nice where did you get the keyboard?
  • blittledblittled Posts: 695
    edited 2009-09-29 02:24
    mikediv: I got the keyboard from Bean (Hitt Consulting) at the UPNE. You probably could e-mail him since he seemed to have quite a few of them. The forum link for the keyboard is http://forums.parallax.com/showthread.php?p=702473
  • SamMishalSamMishal Posts: 468
    Hi Blitted,
    I followed your link for the keyboard and got lots of information.
    I have one question though...I could not see the answer for it....The Tx pin is said to be Rs232 ....is it TTL level Asynchronous Serial
    or is it RS232 (+12V to -12V) I think it is TTL and is 3.3V at that since that is the power to the keyboard....but I just want to make sure????
    Please let me know...
    Very nice set up you have by the way...I like the clear plastic work....nice!
    Samuel
