writing a program to read the usb inputs
i had this idea the other day for my homemade cnc mill, i have been using a prop board and an itl 710 display, what im kinda looking for is how to output something from the prop to the usb port of the computer with a usb to serial converter. i want to read the data in using a java gui. the problem...i dont know how to read the usb ports using java. any idea where i should start.
import java.io.*; import java.util.*; import javax.comm.*; public class SimpleRead implements Runnable, SerialPortEventListener { static CommPortIdentifier portId; static Enumeration portList; InputStream inputStream; SerialPort serialPort; Thread readThread; public static void main(String[noparse][[/noparse]] args) { portList = CommPortIdentifier.getPortIdentifiers(); while (portList.hasMoreElements()) { portId = (CommPortIdentifier) portList.nextElement(); if (portId.getPortType() == CommPortIdentifier.PORT_SERIAL) { if (portId.getName().equals("COM1")) { // if (portId.getName().equals("/dev/term/a")) { SimpleRead reader = new SimpleRead(); } } } } public SimpleRead() { try { serialPort = (SerialPort) portId.open("SimpleReadApp", 2000); } catch (PortInUseException e) {System.out.println(e);} try { inputStream = serialPort.getInputStream(); } catch (IOException e) {System.out.println(e);} try { serialPort.addEventListener(this); } catch (TooManyListenersException e) {System.out.println(e);} serialPort.notifyOnDataAvailable(true); try { serialPort.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE); } catch (UnsupportedCommOperationException e) {System.out.println(e);} readThread = new Thread(this); readThread.start(); } public void run() { try { Thread.sleep(20000); } catch (InterruptedException e) {System.out.println(e);} } public void serialEvent(SerialPortEvent event) { switch(event.getEventType()) { case SerialPortEvent.BI: case SerialPortEvent.OE: case SerialPortEvent.FE: case SerialPortEvent.PE: case SerialPortEvent.CD: case SerialPortEvent.CTS: case SerialPortEvent.DSR: case SerialPortEvent.RI: case SerialPortEvent.OUTPUT_BUFFER_EMPTY: break; case SerialPortEvent.DATA_AVAILABLE: byte[noparse][[/noparse]] readBuffer = new byte[noparse][[/noparse]20]; try { while (inputStream.available() > 0) { int numBytes = inputStream.read(readBuffer); } System.out.print(new String(readBuffer)); } catch (IOException e) {System.out.println(e);} break; } } }▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Don't worry. Be happy
