generating a random number in a certain range
How would i go about generating a random number in a certain range, say between 0 and 255, i have looked in the manual at the "?" command but i dont think i fully get how it works. also is there a way to generate this random number to hit higher or lower numbers more frequently than others.
gives you a random number +-2,147,483,648
?//255
will give you a random no +-255
||(?//255)
will give you a random no 0-255
Var? returns the next random number in the LFSR sequence, and updates Var to that value so the next Var? returns a different random number. ?Var returns the previous number in the LFSR sequence. See page 159 in the Propeller Manual for more details.
Because ? is based on an LFSR, the random number sequence will cycle through all 2^32 values before repeating a value (i.e. uniform distribution). If you want a non-uniform distribution, then you will need to perform some kind of operations using Var to bias the result as desired. (e.g. Result := ?Var / (>|Var+1) would produce an interesting zero biased non-uniform distribution.)
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
anyNameValue is a placeholder. As it's name implies, use any name you want.
In this line:
#> 0 sets the lowest generated number to 0, and <# 255 sets the highest generated number to 255.
Of course, this is assuming that you are using the RealRandom object.
Hey! I'm Adam.
But YOU can call me ziplock.
Blog: braindrink.wordpress.com
"The only problem with the gene pool is that there is no lifeguard." -David Gerrold
John Abshier
? is not really random btw
If you want a number between 256 and 511 take the 32 bit number returned by the random number generator, multiply it by 256, divide it by 4,294,967,295 (hex FFFFFFFF), and add 256 to it.
Multiply by 256 will overflow the 32 bit result for most of the initial random numbers. Leaving rrrrrr00 HEX, where "r" is a random hex digit. This number may be positive or negative.
Divide by FFFFFFFF HEX is a divide by minus one which does not help.
Lets say you want a random number between 100 and 200 (a span of 101) and you have a random number algorithm that produces numbers from 0 to 1 (with a sufficient number of digits). If you take the random number produced, multiply it by 100 and round it to an integer you will end up with a number between 0 and 100. Add 100 and you have numbers in the range you want.
In many cases a lot of the calculations can be done using binary arithmetic and shifts. The key concerns are having a random number generator that produces numbers with a large enough range and sufficient randomness, and maintaining precision during the calculations.
PUB rand (maxv, minv) '' Return a psudo-random value between maxv and minv (inclusive). IF (minv > maxv) RETURN false IF (minv == maxv) RETURN maxv RETURN (||?cnt // ((maxv - minv) + 1)) + minv▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
April, 2008: when I discovered the answers to all my micro-computational-botherations!
If ?cnt ever evaluates to $8000_0000, the return value could be less than minv.
Open question: can ?cnt ever be $8000_0000?
Someone correct me, if I'm wrong. But that doesn't matter. The idea is maxv-minv gets the difference (which is the true range), then random number within the "range" is added by minv to produce the correct values.
Did that help at all...or is that just confusing for everyone.
Some of my objects:
MCP3X0X ADC Driver Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library Don't make strings the bane of the Propeller, bend them to your will!
Post Edited (Bobb Fwed) : 9/26/2009 7:19:41 AM GMT
||$8000_0000 is $8000_0000. In decimal, ||-2147483648 is -2147483648 (still negative!).
I have never noticed the method returning negative (or otherwise unexpected) numbers, but there is only a 1 in 2^32 chance...
I have also used a slightly modified version where the address of a real_random long was passed to the method and replaces the pseudo random system...that's always nice to use. ...same fix would be needed for that one. Thanks for the info about the odd ?bug? with ||.
Some of my objects:
Post Edited (Bobb Fwed) : 9/26/2009 9:04:47 AM GMT
