Can you read prop ram or eeprom back into the IDE??
Hi guys I never had to think about this before but I now have a situation where I would like to read the code that was loaded into my prop proto board. Is this possible? here is the scenario.
I wrote a spin program used F11 to load it into my prop proto board. Everything is working fine. Now I want to be able to read the code I loaded into eeprom I don't care if its spin or asm I just want to be able to read it back then save it and use the program to load into another prop board. Thanks
download the contents of the EEPROM to a .bin file and write that to another board.
OBC
New to the Propeller?
Does anyone know what I have to do to use it with other prop based boards?
In any event, it's a bit of work.· It would be possible to get a 10MHz clock crystal and plug it into your Protoboard or Demo Board or whatever and run the Propeller as if it were on a Hydra board, but the I/O pin part isn't as easy to fix.
video pins and the speed. No issues otherwise.
Given a day, I think I still have the copy I modified on my basement PC and
I'll hook it up and locate it if needed.
OBC
I am really surprised no one has modified it
from the eeprom to the prop at bootup?
Then store it into a file.
"Where am I? Where am I going? Why am I in a handbasket?"
So if I could just read back the modified program into a file "mikesnewblah blah""" then I would only have to load one spin program into a new prop board in one step and it would have this new version of my code.. It sounds simple but I have not found a way to load an image of the eeprom. I have used Ham on my Hydra and it works great but the other prop boards are not Hydra's they are just prop proto boards no video or keyboard.
to the i2c lines to capture the data as it was sent to the prop.
But perhaps you could just create a small subroutine that would run
in a prop cog and just read the eeprom data and send it to a pc using serial??
Then once your slightly modified program is stored into the eeprom you
could just tell the program to read and send over the contents for re-use.
If you write this and get it to work I'd sure like a copy
- sort out your clock setup (16/5 vs 8/10)
- use TV.spin for the TV driver and Graphics.spin for the graphics driver (i.e. the propeller tool built-in drivers, the Hydra drivers only work there)
- change tvparams.tv_pins to %001_0101
Upload the HAM driver to the board, start the PC frontend, select your max EEPROM size and download.There are potentially other places which need attention when you don't run at 80MHz (e.g. the serial driver has a hard-wired 80MHz system rate). Graphics can be removed (I didn't even know until now that it displays anything at all [noparse]:)[/noparse]
Would it be possible to make a version of the program that reads the sensors and outputs the data somehow so that you could manually insert the modified values into the Spin source code?· It seems like that would be a lot more convenient long-term.
localroger, I may just have to look into doing that but to be honest I thought it would be fairly easy to save a bin of the eeprom I did not foresee the complexity.
Holly that is not a bad idea I am very familiar with using sniffers I never thought about trying to capture the data like that . I still think this Ham program is greatly under used it seems ot me that it has so much potential I am really surprised everyone is not using it to some degree.
For the time being I am going to expend some effort on trying to get Ham to work you guys should try it out
Thanks guys
Try the attached. I think it will do what you want. It will even adjust the checksum to accommodate any data that you've stored in EEPROM. But, best of all, it doesn't require any of that bloated .NET nonsense to run!
Please let me know how it works out for you.
Note to developers: If your apps require .NET to run, please consider switching to a different development platform. You're doing your users an extreme disservice by requiring it, and there are plenty of free alternatives that are at least as functional. I prefer Perl, but other choices abound in profusion. Thanks.
Update: The original program wasn't deleting all of its temporary files, especially when interrupted. This has been fixed, and SIGs are now being trapped for a more graceful exit.
Post Edited (Phil Pilgrim (PhiPi)) : 9/27/2009 5:02:54 AM GMT
Thanks for posting that! I hadn't had a chance to pull the hard drive out of my old machine
and run down the changes. That sounds exactly like what I did to get HAM running over here.
OBC
Nyamekye,
But I still think everyone should take a look at Ham its a heck of a program
Also, I would like to know how many users can successfully run the upload program.
Works for me after removing one of my com ports.
--Steve
Propeller Tools
What features would you want in a GUI? I could do it, but it would become more heavyweight as a result. Did you have a Prop connected to more than one com port? The unload program is not fussy about which one it chooses. I could add a port parameter to the command line if it's a problem.
Phil, the link is here: http://forums.parallax.com/showthread.php?p=841845
The goal: compare the same simple GUI application and user experience for platforms produced by different development environments. So far we have comparable entries for Java, Python PyQT, and PBasic. Pending are C++Qt and C++wxWidgets. Someone mentioned Perl and I thought you might show up at some point. Would be nice if you do.
--Steve
Propeller Tools
How did I miss that thread?!! (Maybe I saw the ".net" in the title and just drove by.
