Flux for the SchmartBoard
Hello all,
I just got my SchmartBoard in the mail the other day, and in reading the manual, I found that soldering the board requires flux. Unfortunately, it does not specify what kind, saying only "standard flux".
Does anyone know what kind of flux I should use?
And, for that matter, do I clean the flux off with isopropyl alcohol as suggested to clean the board in the first place, or what?
use isopropyl alcohol to clean off flux
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Flux and isopropyl alcohol should be used when ever you solder.
I have not herd any good reviews but I can say it will be easier then my pcb.
I elected to use only the surface mount components. It would have been nice if the instructions included information on identifying and orienting these itty bitty things. I had no idea which way to install the LED, it was a 50/50 thing and I got lucky.
Everything worked on the first try. Soldering on the Propeller chip and regulators was really easy, the others, not too bad. I did file my soldering tip to a nice point beforehand, that helps a lot.
Biggest gripe I have, now that it's finished, is that there are no pin markings - anywhere. Yet there is plenty of room to include said markings on the board?!
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Thanks for confirming the isopropyl alcohol bit, but II tried looking for the product you mentioned, and couldn't find it.
I'd really just like to know the specific kind of solder to purchase, if that's possible.
At that rate, will zinc chloride flux work? Or is there a specific kind of that?
Post Edited (velociostrich) : 9/24/2009 11:14:15 PM GMT
Unfortunately, I don't have a very old tube of RadioShack rosin soldering flux.
EDIT: Something just came to mind -- is it that they assume that you would be using solder without flux that they tell you to use flux separately, and so if I have solder with flux I'm fine, or no?
Post Edited (velociostrich) : 9/24/2009 11:19:55 PM GMT
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
As for solder buy as thin as you can find. Either 63/37 or lead free. I use lead free so I can sell in europe but 63/37 is easier.
It seems that they don't have it in the tube anymore but this is the same stuff.
Rich H
Ok, thanks, then the zinc chloride stuff that I have will work.
and I guess the rubbing alcohol to clean up the flux? thanks guys
is it necisary no. will it make your life easier yes.
http://www.newark.com/multicore-loctite/m293320/mf-x3210i-mini-fluxer-no-clean/dp/72C1235
Rich H
FYI, you should never file your soldering iron tip (assuming it's a coated tip, like just about every tip is anymore). It basically ruins it... although I guess if it was already bad, it doesn't really matter (it definitely shouldn't be your first resort, and I haven't done it since the first time I ruined one). This thread: http://www.electronicspoint.com/sharpen-and-re-tin-soldering-iron-tips-t73951.html is a good discussion about it.
I typically keep my tip clean w/ a sponge, with my preference being the metal sponge, like: http://www.curiousinventor.com/store/product/2 . You could also buy tip cleaner (Radio Shack sells it), which works pretty well too. Eventually, you should probably just buy a new tip though (eventually, as in I'm still on my original tips for my soldering irons, which are all at least 4 years old, and they get a LOT of use).
DogP
I didn’t have any flux lying around when I got my SchmartBoard, I also had a tip that was as wide as two of the propeller or eeprom leads. I tried to put the thing together anyway. Well, it all got soldered into place, and it all had continuity when I checked with a DMM. However, when I hooked power up, smoke started coming from the lower voltage regulator / LED area, then the LED dimmed. Woops, fried a board.
So I bought some flux and a better iron tip. I ordered two more boards (because they were on sale for $30 at the time). I will give it another go.
@Microcontrolled: You asked why anyone would want one of these boards. I got it because it is ridiculously small, some people have applications that would benefit from that profile, I am one of those people.
I am building a new test rig and will soon be offering with headers not attached. seems more useful for most that way.
No it was not plated, just a cheap solid copper tip that I dress up and re-tin when it starts to look like a snake's tongue. It is considerably shorter than it used to be. [noparse]:D[/noparse]
Rich H
He said plumbing solder is 50% tin and 50% lead while electrical solder is 63% Tin and 37% lead.
He said the problem you will have with the wrong kind of solder is corrosion.· The life of your product may be determined by the quality of solder used.
I'm not sure what has changed since·my Dad·has worked but there is a thing called lead free solder.
You probably want to use lead free rosin core solder.
63/37 is better then lead free but you can not sell in europe if your product contains lead.
http://en.wikipedia.org/wiki/Solder
