filter out noise of EMIC
Hello All,
I have an EMIC that I've been tinkering with, and no matter how much altering from the programming side, I can't eliminate the noise in the background - when she "speaks". Is there an RC circuit I can apply (I'm a novice, so that's what I'm thinking) to filter out the noise?
Any advice would be very helpful.
Shmow
Shmow
The EMIC is powered from the 5VDC terminal on the prop demo board.
I have a 1k ohm resistor in series between the "SOUT" pin on my prop and the SIN pin on the EMIC.
The two EMIC GND pins are connected to the demo board's VSS terminal.
The noise has a hissing quality to it, but I believe it could be just the distortion of the voice.
Shmow
The sound is like the hissing sound you hear from walkie-talkies.
Don't worry. Be happy
Mike2545
This message sent to you on 100% recycled electrons.
The first stage of speech synthesis is a hiss or noise generator that is subsequently modulated in the vocal tract, and I suspect that what we hear is the residue of that. You can learn a lot about speech by looking at Chip's development of the speech synth object for the Propeller.
Tracy Allen
www.emesystems.com
