using voltage divider to power propeller
Hello All,
I have a propeller running a few components:
one - 912Mhz transceiver (3.3VDC)
three - 7" tall seven segment LED display (24VDC)
The project receives a count down clock update from a master clock and displays the time on a large digital clock - three digits at this time.
I would like to use the power supply for the 7 segment displays (24VDC - 3A) to power the entire circuit (instead of two different power supplies - 24VDC and 7.5VDC).
I thought I could use the voltage divider. I set up the divider to get an 8.5VDC output.
I tried just powering the propeller alone with a couple of LED outputs as a test.
The voltage divider output was measured at around 8.5VDC but there didn't seem to be enough current (an uneducated guess) to power this simple prop circuit.
Is there something I'm missing?
What may be the problem?
Cheers,
Shmow
Cheers,
Shmow
Is there a reason that you are driving the LEDs with 24 volts? LEDs by themselves are current driven devices and don’t care too much about voltage. At least within a wide range.
If there is some reason that you cannot use 7.5 volts for your LEDs, how about a regulator like the LM7808 single chip regulator. It can take an input voltage up to 24 volts and will output 8v
Searider
You need a switching regulator that produces the voltage needed for the transceiver and the Propeller. TI and others make switching regulators that can take 24VDC and produce regulated 3.3V with little heat produced. If you can't use a switching regulator, then you could use something like an LM7812 to drop the 24V to 12V and another regulator after that to produce the 3.3V needed. You'll need a heat sink for the LM7812 and for the 2nd regulator because the voltage drops are so large ... there'll be a lot of heat dissipated. (21V x 100mA = 2W).
*Peter*
P.S. ditto Mike
thanks for your input; I will try the LM7808 that you recommended.
The large LED displays require 24VDC (digi-key part # 160-1022-ND).
Cheers,
Shmow
is there a heat sink you would recommend? I am designing a PCB to put this circuit together so I can fit in the regulators and the heat sink. I'm a bit of a novice with heat sinks as I have never done them before.
What if I install a basic fan next the PCB; would that be enough without the heat sink (just thinking out loud here.)
Shmow
Thanks for all your help folks.
Cheers,
Shmow
Heatsinks can be as big as you can afford space for, fans always annoy, eventually.
Style and grace : Nil point
I am following the diagram for the PE Educartion kit which uses 3.3v for the propellor and 5V for powering other components I bought the two 'regulators or are they a type of transistor at dick smith electronics here in Queensland.
Sorry bout the big type , I was just playing [noparse]:)[/noparse]
Mike.
Post Edited (greenspinner) : 9/22/2009 8:11:42 PM GMT
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.2.pdf
Page 26 has the supply voltage requirements.
The interfacing to higher voltage parts is usually via resistors to limit the pin protection current to 500uA or less (although most use 1K, which gives a higher current to the protection diodes). There are also all sorts of official interfacing chips.
I have ran a Prop on about 4.2Volts for a project, to allow a Z80 to run, low volts, direct to the Prop. nothing bad has happened (yet) but this is very much outside of the original specs. Others run them on higher clocks, than the specs.
They do seem to be resilient little beasties but I would get to know him a bit better, before any punishment gets metered out.
