Hi Paul,
Thanks, glad you're happy with it- I'm really excited about this new method of integrating ViewPort into all sorts of applications. While DDE is ancient, it's perfect for this purpose- it's simple and it works! Yes, the data in ViewPort is pure- arrays are from one sample(the conduit provides an indicator that tells when you should burst your samples into the array- similar to the vertical refresh signal from monitors) and values are atomic and use out of band markers. Lots of complex stuff behind the scenes that makes it trivial to share data from the Propeller with Windows applications. Sleeping is overrated, raising kids the right way takes time... ViewPort's DDE client and server are working well- will do a bit more testing/documentation/samples. Am working on Spinner/PropScope/book/ViewPort in parallel, but expect a new release end of this week (end of July).
Hanno
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Download a free trial of ViewPort- the premier visual debugger for the Propeller
Includes full debugger, simulated instruments, fuzzy logic, and OpenCV for computer vision. Now a Parallax Product!
Here's the complete VB.NET code to do pretty much anything with programs running on a Propeller. You can load a spin file, list variables, get details for variables, retrieve values and change values- for single variables as well as arrays. Also, triggers and callbacks and a variety of formats... DLL source code will be open... Now I need to sleep- tomorrow some last testing and then it's baked!
Hanno
'vpClient Sample Application'August 2009 v0.5 mydancebot.com 'This program demonstrates how to use the vpclient dll to interface with the ViewPort library. 'Your program needs to include the "vpclient.dll" as a reference.'This program maps each vpclient function to a button to allow you to try out the full functionality.''You typically start and stop each session by calling "connect" and "disconnect".'During a session use: "execute" to perform commands- like telling ViewPort to load a spin file.' Use "request" to retrieve data from ViewPort- like the value of a Spin variable or array.' Use "poke" to send data to ViewPort, for example- changing a Spin variable to a new number.' Use "startAdvise" to start an advise loop, the "advise" event will fire with your requested data''Each function returns with a status string. If an error has occured, the status will start with an exclamation mark'The "advise" and "request" functions require a "format". Use 1 to get numbers in scientific notation with units' Use 2 to get raw integers. Use 4 to get raw bytes.'View the "mainform_load" function to see what commands you can useImports vpClient
PublicClass MainForm
DimWithEvents vp As vpClient.Main
PrivateSub connectB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles connectB.Click
statusT.Text = vp.connect()
EndSubPrivateSub disconnectB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles disconnectB.Click
statusT.Text = vp.disconnect()
EndSubPrivateSub executeB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles executeB.Click
statusT.Text = vp.execute(executeC.Text)
EndSubPrivateSub requestB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles requestB.Click
Dim format AsInteger = Val(requestformat.Text)
Dim b AsByte() = Nothing
statusT.Text = vp.request(requestC.Text, format, b)
resultT.Text = vp.decode(b, format)
EndSubPrivateSub pokeB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles pokeB.Click
statusT.Text = vp.poke(pokeC.Text, pokeDataT.Text)
EndSubPrivateSub startAdviseB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles startAdviseB.Click
statusT.Text = vp.startAdvise(adviseC.Text, Val(AdviseFormatT.Text))
EndSubPrivateSub stopAdvise_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles stopAdvise.Click
statusT.Text = vp.stopAdvise(adviseC.Text, Val(AdviseFormatT.Text))
EndSubPrivateSub doAdvise(ByVal b AsByte(), ByVal format AsInteger) Handles vp.advise
AdviseT.Text = vp.decode(b, format)
EndSubPrivateSub MainForm_Load(ByVal sender AsObject, ByVal e As System.EventArgs) HandlesMe.Load
vp = New vpClient.Main(Me)
Dim file AsString = Application.StartupPath + "\ddesample.spin"
executeC.Items.Add("connect disconnect".Split) 'connect/disconnect ViewPort to/from the Propeller
executeC.Items.Add("link(n,myserver|get!n)") 'when the dde server's value changes, ViewPort variable "n" will change
executeC.Items.Add("unlink unadvise".Split) 'clear all "links" or "advise" loops
executeC.Items.Add("load(" + file + ")") 'compile and load the file to the Propeller and connect
requestC.Items.Add("list") 'lists all variables available to poke/request/advise
requestC.Items.Add("detail(n)") 'provides details on variable "n"
requestC.Items.AddRange("n m n_m".Split) 'retrieves the value of 1 or more variable values
requestC.Items.AddRange("$spacer $update".Split) 'use these special variables to set the spacer between variables, and the update rate in milliseconds
pokeC.Items.AddRange("m n $spacer $update".Split) 'set the value of a single variable
adviseC.Items.AddRange("n m n_m rise_n_5000_n_m".Split) 'rise_n_5000_n_m sets a trigger which returns the value of "n" and "m"'a trigger starts with "rise" or "fall" followed by the variable and the trigger value. Specify the result at the end
adviseC.SelectedIndex = 0
executeC.SelectedIndex = 0
requestC.SelectedIndex = 0
pokeC.SelectedIndex = 0EndSubEndClass
Outstanding Hanno, Outstanding!
I am not a VB coder, but it should be easy to connect to your dll from my Delphi or LabView drivers. I will post the results.
1) Do you know if your .NET dll requires .NET compatible calling codes? I think my Delphi has a .NET variant, not LabView.
2) An option with ViewPort closes the Conduit if VP loses the focus. Is the DDE system still active in this case?
3) Does your VP code call the propellant dll to compile/load? Could this be made user selectable (eg bst, homespun) since these variants are starting to show some very interesting options etc.
See, sleep does have some practical aspects!
Cheers!
Paul Rowntree
Outstanding job! That is the code I wrote for handling DDE callback messages myself, after referring to code I wrote 10 years ago for an international bank.
Simple, reliable and fast. Yay!
This morning I whipped together a Python client for ViewPort- lots of fun, here it is:
#open the connection to ViewPortimport win32ui,dde,sys,time
ddeClient = dde.CreateServer()
ddeClient.Create("")
vp = dde.CreateConversation(ddeClient)
vp.ConnectTo("vp", "system")
#compile, load, and connect to a spin file
vp.Exec("load("+sys.path[noparse][[/noparse]0]+"\sample.spin)")
print"Spin file is sharing these:"+vp.Request("list")
#request and poke a variableprint"Variable m's value is:"+vp.Request("m")
vp.Poke("m","1234")
time.sleep(.1)
print"After a poke, its value is:"+vp.Request("m")
raw_input("Press Enter to exit")
Enjoy!
Hanno
On another thread http://forums.parallax.com/showthread.php?p=841655 heater and CRM requested that ViewPort include a web server to allow cross-network/cross platform api access. dMajo brought up the excellent point that DDE already supports a "network service", so in theory, ViewPort should already support DDE access by multiple clients, connecting from multiple machines in multiple languages. From quick googling, it looks like non-windows os's support DDE- including non-windows applications- including OpenOffice.
Hanno
My Google for "linux dde" only comes up with this:
"the problem with what you are trying to
do (and why you don't find it) is this : DDE and OLE and DCOM are
proprietary MS interfaces. The support for them exists only on MS
platforms (Windows)."
and then stuff about the Linux "Device Driver Environment".
Your second link there is a Tcl man page and says " This command allows an application to send Dynamic Data Exchange (DDE) command when running under
Microsoft Windows."
Not sure what the first one is about[noparse]:([/noparse]
For what it is worth, I have searched for DDE support under Lazarus (Free Pascal Compiler) but no joy so far. I take this to mean that no-one has created a look-alike for the linux os. On my LabVIEW system the DDE support is buried under the 'Platform' set of vi's, which are supposed to be platform-specific.
Cheers!
Paul Rowntree
Hanno
Hanno
'vpClient Sample Application 'August 2009 v0.5 mydancebot.com 'This program demonstrates how to use the vpclient dll to interface with the ViewPort library. 'Your program needs to include the "vpclient.dll" as a reference. 'This program maps each vpclient function to a button to allow you to try out the full functionality. ' 'You typically start and stop each session by calling "connect" and "disconnect". 'During a session use: "execute" to perform commands- like telling ViewPort to load a spin file. ' Use "request" to retrieve data from ViewPort- like the value of a Spin variable or array. ' Use "poke" to send data to ViewPort, for example- changing a Spin variable to a new number. ' Use "startAdvise" to start an advise loop, the "advise" event will fire with your requested data ' 'Each function returns with a status string. If an error has occured, the status will start with an exclamation mark 'The "advise" and "request" functions require a "format". Use 1 to get numbers in scientific notation with units ' Use 2 to get raw integers. Use 4 to get raw bytes. 'View the "mainform_load" function to see what commands you can use Imports vpClient Public Class MainForm Dim WithEvents vp As vpClient.Main Private Sub connectB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles connectB.Click statusT.Text = vp.connect() End Sub Private Sub disconnectB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles disconnectB.Click statusT.Text = vp.disconnect() End Sub Private Sub executeB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles executeB.Click statusT.Text = vp.execute(executeC.Text) End Sub Private Sub requestB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles requestB.Click Dim format As Integer = Val(requestformat.Text) Dim b As Byte() = Nothing statusT.Text = vp.request(requestC.Text, format, b) resultT.Text = vp.decode(b, format) End Sub Private Sub pokeB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles pokeB.Click statusT.Text = vp.poke(pokeC.Text, pokeDataT.Text) End Sub Private Sub startAdviseB_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles startAdviseB.Click statusT.Text = vp.startAdvise(adviseC.Text, Val(AdviseFormatT.Text)) End Sub Private Sub stopAdvise_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles stopAdvise.Click statusT.Text = vp.stopAdvise(adviseC.Text, Val(AdviseFormatT.Text)) End Sub Private Sub doAdvise(ByVal b As Byte(), ByVal format As Integer) Handles vp.advise AdviseT.Text = vp.decode(b, format) End Sub Private Sub MainForm_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load vp = New vpClient.Main(Me) Dim file As String = Application.StartupPath + "\ddesample.spin" executeC.Items.Add("connect disconnect".Split) 'connect/disconnect ViewPort to/from the Propeller executeC.Items.Add("link(n,myserver|get!n)") 'when the dde server's value changes, ViewPort variable "n" will change executeC.Items.Add("unlink unadvise".Split) 'clear all "links" or "advise" loops executeC.Items.Add("load(" + file + ")") 'compile and load the file to the Propeller and connect requestC.Items.Add("list") 'lists all variables available to poke/request/advise requestC.Items.Add("detail(n)") 'provides details on variable "n" requestC.Items.AddRange("n m n_m".Split) 'retrieves the value of 1 or more variable values requestC.Items.AddRange("$spacer $update".Split) 'use these special variables to set the spacer between variables, and the update rate in milliseconds pokeC.Items.AddRange("m n $spacer $update".Split) 'set the value of a single variable adviseC.Items.AddRange("n m n_m rise_n_5000_n_m".Split) 'rise_n_5000_n_m sets a trigger which returns the value of "n" and "m" 'a trigger starts with "rise" or "fall" followed by the variable and the trigger value. Specify the result at the end adviseC.SelectedIndex = 0 executeC.SelectedIndex = 0 requestC.SelectedIndex = 0 pokeC.SelectedIndex = 0 End Sub End Class
Cheers!
Paul Rowntree
Family First - everything else second.
Have a good one, Hanno.
JMH
Beta of ViewPort v4.2 is here: mydancebot.com/viewport/beta.php
A video and link to download the sample clients is here: mydancebot.com/viewport/clients.php
#open the connection to ViewPort import win32ui,dde,sys,time ddeClient = dde.CreateServer() ddeClient.Create("") vp = dde.CreateConversation(ddeClient) vp.ConnectTo("vp", "system") #compile, load, and connect to a spin file vp.Exec("load("+sys.path[noparse][[/noparse]0]+"\sample.spin)") print "Spin file is sharing these:"+vp.Request("list") #request and poke a variable print "Variable m's value is:"+vp.Request("m") vp.Poke("m","1234") time.sleep(.1) print "After a poke, its value is:"+vp.Request("m") raw_input("Press Enter to exit")
Enjoy!
Hanno
Hanno
https://bugs.launchpad.net/ubuntu/+source/openoffice.org/+bug/49163
http://developer.apple.com/mac/library/documentation/Darwin/Reference/ManPages/mann/dde.ntcl.html
Hanno
Microsoft Windows."
Cheers!
Paul Rowntree
It's an OLD technology, came out about the time of "drag and drop" - actually, that might be DDE based.
StoneKnives -> DDE -> COM ->DCOM ->.Net
(and not necessarily an "evolutionary" step forward [noparse]:)[/noparse])
