Digital Pot, DAC or ??? - to replace 2 axis inductive joystick
I am still trying to get my wheel chair controller to work. Decoding the serial stream didn't work out so now I am looking to replace the pots. However, the two axis pot really isn't a pot, it is a non contact inductive joystick. Look here for the patent if you're interested.
The joystick has the following wires;
Black = ground
Red = 11.78 volts (supply)
Green = 5.88 volts
Blue = 4.72v/5.76v/7.05v (left, center, right on the x axis)
Yellow = 4.62v/5.85v/7.03v (back, center, fwd on the y axis)
From what I have read about similar joysticks, the green wire is probably to indicate that the joystick is functioning properly.
What would be the best way to replicate these signals?
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Post Edited (W9GFO) : 9/21/2009 6:16:43 AM GMT
Black = ground
Green = 5.88 volts
Rich H
We have some industrial equipment here that uses similar joysticks, their non-mechanical nature makes them more reliable for heavy use.· Some linear position sensors also work in the same manner.
