Please help out a Newbie here..
Hi, I am trying to build autonomous vehicle because of a college project.
However I had absolutely no experience building a robot.
Is there anywhere I can start off by...
I was reading this article
http://www.blogcadre.com/blog/jason_striegel/howto_make_a_robot_car_-_part_1_overview_2005_10_25_13_22_21
It was helpful.. but some stuff i still cant understand
And i am really not sure which type of sensor to use in an indoor environment
Which one is easier, camera or GPS
Any help will be appreciated.
thx
extra info, basically this race will be indoor.
there would be random obstacles in the course that we have to avoid.
And we basically can use anything we want, but our grade will be based on our originality and design.
My group is thinking about using a camera, and someone mention it is really hard to figure how to use it.
Can someone suggest a camera at a ok price to buy, and what i should read on how to integrate it into the system.
Post Edited (nonamehero) : 9/22/2009 9:42:13 PM GMT
thx
As for the camera or GPS issue, GPS is generally very simple to use, but it only works outdoors. A camara will work indoors, but it is difficult to use with a low cost microcontroller such as what Parallax sells. Even with an embedded computer, a camera is no small feat.
store.nutsvolts.com/product.php?productid=16787&cat=251&page=3
- Stephen
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
For those of you who are at least proficient with robotics, please correct me if I'm wrong but I thought the best way to become an expert with robotics was to first obtain a hands-on grasp of the basics. By learning about all simple aspects of robotics (programming, input, processing, output, chassis design/construction, et cetera) you'll begin to have the tools necessary to solve problems like the one you described.
I believe the process is similar to learning a language: as robotic knowledge increases, problem solving becomes more efficient and effective. There is no substitute for experience. Get a Boe-Bot, toss it together, follow the book, learn about robotics by actually doing it.
That's how I'm starting out and next week I'm probably going to have the necessary skills to build "Ultra-Super-Mega-Tron," the robot that builds other robots which rule the world (in the voice of Simon Bar Sinister).
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Boe-Bot/List/0/SortField/4/ProductID/302/Default.aspx
does this robot work indoor, and what sensor does it use, how does it avoid obstacles?
"A complex design is the sign of an inferior designer."
I think the USB only version would be preferred - this one:
www.parallax.com/Store/Robots/RollingRobots/tabid/128/CategoryID/3/List/0/SortField/0/Level/a/ProductID/296/Default.aspx
