Medium current driver
I'm looking for a transistor to run a medium current DC motor.
I've got the cables, but can't find a proper MOSFET. Anyone?
Don't worry. Be happy
However, we need to know what kind of voltage you are talking about as well...
dev/null,
You need to provide more information on your motor. If you are dealing with 12500 Amps, then I'm sure that a single MOSFET won't cut it for you. The art of combining MOSFETS in parallel to achieve very high current control can be very tricky, everything must be perfectly balanced.
About the highest current controller of that I am aware of is used in the EV (Electronic Vehicle) industry where 500 Amps is common.
Beau Schwabe
IC Layout Engineer
Guys, these cables are used to power a particle accelerator with 1600 magnets at 8 Tesla each! The motor took 7 years to build and cost approx. $1 billion.
The lower wire is a superconductor (zero resistanse) that handles 12K Amps at around 3 Kelvin.
en.wikipedia.org/wiki/Large_Hadron_Collider
You can't kid a kidder.
Serioiusly, what are you working on? If you want a MOSFET recommendation, let us know your specs.
Thanks anyway. Actually, when I think about it, I need a P-channel MOSFET with continuous drain current minimum 60 amps.
I know there is the IRF4905. Are there others?
Mind posting your schematic?
Have fun
Ale
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Here is something comparable to the IRF4905 that you mentioned.
www.st.com/stonline/products/literature/ds/8177/stp80pf55.pdf
It has a lower Rds"ON" than the IRF4905 and can handle 80 Amps.
It would help though to know what your schematic looks like... not all H-bridges are created equal.
Also, to know what voltage you are using. There are some MOSFETS that go beyond 100Amp capabilities and have much lower Rds"ON", but at cost of a lower operating voltage than the 55V limitation indicated by the IRF4905 you mentioned.
Beau Schwabe
IC Layout Engineer
*Peter*
National Semiconductor and TI make some good High-Side mosfet drivers. They are designed to use an N-channel fet in place of the P-channel variety.
Beau Schwabe
IC Layout Engineer
If I want an inductive driver that handles 60+ amps, what is the best way to go? I do not need PWM in particular, the point is to vary the voltage across the motor coils.
(And yes, I want to build it myself)
But If you wanted you would have to do a "normal" linear regulator but for that amount of current... no I wouldn't.
There are MOSFET drivers that take care of keeping just one mosfet in conduction where the other one is in no conduction reducing the losses you will incur when both conduct due to Toff longer than Ton. I'd use one of those, you can also built that yourself. Almost any manufacturer has them: Analog, TI, ST, International Rectifier and so on.
