Keychain DVR - Page 3 — Parallax Forums
Keychain DVR
135
  • hinvhinv Posts: 1,256
    edited 2009-09-15 20:56
    Hi,
    I just got my new 4GB Keychain DVR ebay item#250486006903 seller gadget.topseller88
    Unfortunately, It does not have the microSD card in it, but it does appear to have a CCD camera like
    I got the model number and manufacture from properties of one of the images:
    Manufacturer: Anyka
    Model: AK322x Chip
    On the properties of one of the videos:
    25Frames/Sec
    195kbps
    and I have the small date in the upper left corner.
    Erco, can you tell us what you see on the properties for an image and a video?
    Doug
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-09-15 22:54
    Holly, I think we got the exact same camera. If so, it royally sucks. I got it to record my class lectures(without needing the approval papers and Smile with it- yippee!). However, the camera quality is poor(can't even make out the professors writing on the board 10 feet away, AND the darn thing isn't even reliable for recording... Sometimes, after recording for 30 minutes or so, I check the camera on my laptop, and it didn't even record anything, OR it only recorded the first 5-7 minutes! I'm VERY dissappointed in this particular camera.
    Erco, any chance you can get a batch of GOOD cameras this way sometime soon? I'm going to try and send this camera back to the seller and tell them that their sample videos and images are were clearly not taken with THIS camera(false advertising?)
    edited 2009-09-15 22:59
    @hinv
    Check your video files using virtualdub and see if you have the same
    12.5fps rate as I do. There are 25fps, but on mine the same frame is repeated twice.
    [noparse][[/noparse]0 1] [noparse][[/noparse]2 3] [noparse][[/noparse]4 5] [noparse][[/noparse]6 7] = 4 different frames... not 8.
    Perhaps you could post a test video clip from your cam?
    http://www.ziddu.com/ is a good place to upload a file anonymously.
    The exe you sent me writes 2 files to the root dir of the flash drive in the cam
    setdate.txt
    this contains a date in exactly this format
    2009-09-15 16:10:05
    same with the time file
    time.txt
    2009-09-15 16:10:05
    Yes, they both have the same data... No idea why they did not just
    use one file to signal both data sets to the cpu???
    I expected this would reset the time when the cam
    next booted up...but it did not? The time remains the same :-(
    Is there some extra action that needs to be taken I wonder??
    The instructions in the 'manual' are obscure, to say the least.
    I'm hoping the cam uses an ARM cpu....
    I will pop it open sometime soon when I
    have the time to hack and see.
    I suspect that you can reprogram the flash code
    inside the cpu by placing a data file in the root dir
    much as the time is set....if so this may make a great
    I'd like to remove the resizing code that ruins the 640x480 stills
    the camera is taking. the resulting images would look better
    and take up much less space, also you could take images faster
    without that resizing taking place every time you click for a
    picture. If I can pull the contents of the flash out I can find the
    name of the data file that would reprogram the flash on reboot.
    I was supposed to get another, hopefully different, cam in the mail
    today but it did not arrive :-(
    I called the post office and they said they would make sure she
    had the box with her tomorrow.
    This cam is not nearly as good as the 4gb ccd one but it is
    still acceptable as a security camera, and the audio is quite clear.
    It does have 8gb of flash drive space...and that alone is worth
    about what I paid so it's not all bad.
    If I can just find the hoop to jump through to get the clock reset...arrgh
    "Where am I? Where am I going? Why am I in a handbasket?"
    edited 2009-09-15 23:28
    OK, success!
    I reformatted the flash drive using fat32 and quick format
    under windows....then I ran the weird little time setting .exe
    and the time was reset. (I also sacrificed the poor chicken)
    I suppose that simply creating the txt files and placing them on
    the drive after a reformat would also work...I see no reason it
    would not. Evidently the code in the cpu can only see the txt
    files if they exist all by themselves on the drive!? Who coded these
    things!
    You need to unplug, power down the cam and reboot so that the time gets set
    quickly after you write the txt files.
    edited 2009-09-16 01:12
    BTW, The 8GB camera I got from cititrading shows up as "Anyka AK322x Chip" just like the 4GB unit when I look at the properties of an image taken on it.
    I will send you some video samples via email, and you can tell me.
    Erco, let us know what you find on the batch that comes in. I really want one like you posted to youtube with the microSD. Hopefully this wasn't some big bait&switch scam by the manufacturer.
    edited 2009-09-16 02:42
    Yep, my new 4 GB cams are the same good CCD units. They're not off Ebay,· I buy 'em 10 at a time from China and they ship via DHL. I'm almost sold out again, but if anybody wants one I think I can get it to you for $40 ($35 plus $5 shipping from LA). I should probably order some more! PM me or email erco@netzero.net if you want one.
    edited 2009-09-16 03:14
    Some other difference between the 4GB unit and the 8GB units that I purchased:
    The 8GB unit has a more amplified microphone
    The 8GB unit automatically mounts, but the 4GB does not. I have to mount it with "mount -t vfat /dev/sdc /mnt2" under linux.
    edited 2009-09-16 04:43
    Holly, where did you get the set time program from?
    Chris Savage
    Parallax Engineering
    50 72 6F 6A 65 63 74 20 53 69 74 65
    edited 2009-09-16 07:22
    @Chris
    It was emailed to me by hinv
    It's very strange looking...no english writing on it.
    2 buttons and a text box.
    Pressing the leftmost button creates the 2 txt files
    and places them on the flash drive.
    I can post the exe here as an attachment or whatever if you need it.
    edited 2009-09-16 21:23
    Just got home and 2 more cams were in the mail box.
    Both from different sellers, both the same lower quality units just
    like the one I already had :-(
    One did come in a box with a wall charger and a free trinket.
    But it just has 4gb flash and I paid 5$ extra hoping it was the
    ccd cam...oh well
    Going to try one more time to get some ccd cams.
    edited 2009-09-17 04:22
    How do I tell if the camera I got is a CCD or not?
    edited 2009-09-17 04:47
    @hinv
    If it is ccd it will be shooting video at 29.7fps (they round this off to 30fps but it's actually 29.7)
    use virtualdub to test it....just single frame step through a second of video...if it is 25fps with
    each frame repeating twice then it's the cheap cmos camera.
    The image will not smear as you pan the camera around if it is ccd.
    And the time will appear in the lower right corner in orange digits.
    The cmos cams have the time in white in the upper left corner.
    virtualdub is a freebie
    www.virtualdub.org/
    edited 2009-09-19 23:17
    OK, I got two (yes, another·all-day sucker with size 11 tennis shoes) of the 8G sucky·cititrading units with the off-kilter orientation.· The fine-print Chinglish "instructions" have left me with my eyeballs spinning counter-clockwise, setting aside the bifocals for the magnifying visor.· I managed, somehow,·to do a couple of videos and to take some stills (yuck), but I haven't nailed the process owing to the puzzling multi-function buttoning (really hate that), shooting in the dark as it were.· Anybody got this nailed down and can do a re-write in standard English maybe?· [noparse][[/noparse]BTW, mine don't show any time-stamps at all.]
    Where's a 0101th-grader when you really need one?
    edited 2009-09-20 08:30
    @PJ Allen
    We should get a box full of the good 4gb cams on Mon Or Tue.
    I'm going to compare/contrast the cheap 8gb cams with the better cams
    and write new instructions up. You may have yet a 3rd variation if your
    cams don't have a time stamp on the video.... there are no time stamps
    on the stills.
    A simple exe also needs to be written to easily set the clock on the good ccd cams.
    I will create one when I have time.
    The processor inside seems to go into sleepmode when you turn it off.
    It just watches for button clicks at that point. The time chip always runs
    as long as the battery is charged.
    When you manage to get the cams into video record mode the led is
    switched off so as not to make anyone suspect it's recording.
    You can tell the processor is recording video by holding an am radio
    close...you will hear a lot of hash noise.
    When you plug the unit into a USB port or charger the led will blink
    slowly if the battery is charging...it will remain on and quit blinking
    when the voltage indicates the battery has a full charge.
    When you unplug from USB the cpu watches for a button press and
    if none occurs it goes into sleep mode in a few seconds [noparse][[/noparse]off]
    instructions for stills 8gb cheap cmos cam
    When the cam is in sleep mode [noparse][[/noparse]off] a quick press of the on/off
    button boots the cam up and turns the led on.
    The on/off button is the rear button of the two, the one farthest from
    the front of the cam. When booting you will see the led flicker about
    a second in....no idea why, maybe it indicates boot procedures
    have finished.
    At this point with the led lit steadily if you quickly press the front button
    a still jpg will be taken.
    While a jpg is being processed the cpu turns the led off...when it comes back on
    you can take another jpg.
    Often when you try to take that first jpg the quick press of the front
    button is not recognized #$%^ This is a bug, after a second or so if the led does not blink out
    (indicating a jpg is being processed) just press it again, it always seems to
    work the second time.
    At this point to turn the cam off press and hold the rear button until
    the led goes off...the cam is now in sleepmode again.
    instructions for video
    With cam in sleepmode a quick press of the rear button
    wakes up the cpu and lights the led.
    Hold down the front button until the led blinks 3 times and goes
    off, you are now recording video and the led remains off.
    Sometimes holding the front button down does nothing..the led just stays on!?!?
    This is some sort of program error and to correct it release the front button
    and once again press it and hold until the 3 blinks occur...then release.
    [noparse][[/noparse]No good coder would release a product with a bug like this!]
    OK, you got the 3 blinks and video has been recording and now you want to
    stop recording.
    Simply give the front button a quick press....nothing seems to happen!
    the led remains off? What is happening is the cpu is finalizing the avi
    file and storing it on the flash, after a couple of seconds the led will
    come on and remain on...this means the avi is safely stored away.
    DO NOT interrupt the cpu during the period of pressing the front
    button to quit recording and the led's coming back on and remaining on! If
    you do the avi will often be corrupted :-(
    With the recording stopped and the led on you can either press and hold
    the front button to record another avi, or press and hold the rear button
    until the led goes off signaling the cam is back in sleep mode [noparse][[/noparse]off]
    Oh!, since there is no power switch and the cams cpu is always on in
    some mode or other they put a reset switch that can get you out of
    trouble if the cpu locks up. Look 2/3 of the way towards the rear on
    the USB socket side of the case and you will see a tiny hole. Pressing some
    really tiny object in there resets the processor.
    The USB code in the cam seems a bit weak and sometimes your pc
    won't recognize the device...just unplugging/plugging the cam seems to eventually
    get it recognized. Sometimes it is recognized as USB2.0 but usually, at
    least on my pc it comes up as USB 1.1
    If the cam is in your purse and something accidentally presses the rear button
    and boots up the cam a counter is started and after a minute if no other button
    presses are detected the cam goes back to sleepmode....so no need to
    worry about the battery draining.
    They really need to put all this info in understandable English
    on a slip of paper and send with these cams.
    Post Edited (HollyMinkowski) : 9/20/2009 9:57:59 AM GMT
    edited 2009-09-20 12:56
    Holly,
    Thanks for that assist.· This will go far in keeping me from subjecting the·device under test (DUT) to an unscheduled,·though well-deserved,·series of "shock & vibration."
    edited 2009-09-20 19:02
    That made me of a pertinent fact. If you take the chain off, the whole device fits neatly under the head of my 2lb hammer freaked.gif
    Post Edited (hinv) : 9/20/2009 7:16:57 PM GMT
    edited 2009-09-23 02:19
    Our ccd cams came in...I brought 2 of them home to play with.
    Video quality is amazing for something so small!
    No smearing like the cmos keychain cams...YaY
    (I will find a use for those cmos cams I am stuck with)
    No software bugs that I can find...the button functions
    are all quick and flawless.
    Still have probs getting USB to recognize them as USB2.0
    The video data rate is so large that USB1.1 can't deliver the data
    fast enough to render the file without jerks and pauses...so I
    had to move the avi files to the HD before they would play well.
    My old AMD2400+ pc is not fast enough to render the files well
    at all...had to recompress with virtualdub before that old pc
    could play them. If you get jerky video it's either cpu speed
    is too low or data delivery from the cam is too slow...on the old
    and slow pc some avi's just froze at the start.
    You will want to recompress the avi files anyway...they are just too large
    in raw motion jpeg form. I suggest a 2-pass render using vdub and
    xvid with a data rate of 2000-3000. Mine came out best after lowering
    the color level as it seems a bit high to me. Cropping for 16:9
    aspect still leaves you with a nice image and it zooms to fill a
    widescreen vga monitor....just take 40-43 off the top and bottom,
    or vary that to center on your desired spot so long as total cropped is
    80-86 or so.
    Gordian Knot will deliver a superior xvid avi but it will take
    a while to analyze the avi's because of the huge bitrate...for
    anything over a few minutes its an overnight job or all day
    as a background process.
    Will test to see how long you can shoot video on a fresh
    battery charge tomorrow at work... length will also be
    limited by the fat32 max file size...isn't it 2gb?
    Unlike with the cmos cams you can rapidly take jpg images...
    no more waiting about 4 seconds between shots.
    edited 2009-09-23 02:24
    HM,
    Can you a provide a link for them?
    edited 2009-09-23 13:52
    I was out walking the dog just before sunrise and took a short video clip
    from the back yard. I was curious about the low light ability of these
    cams. It's amazing they work in anything less than bright sunlight
    since the lens opening is considerably smaller than a BB. Having the
    lens opening stopped down this tiny is really great for sharp focus
    but terrible for light gathering.
    I recompressed this clip with virtualdub using xvid codec at 3000kbps.
    I cropped for 16:9 aspect, lowered the color saturation a bit and raised
    the gamma a bit. It was a 2-pass render.
    (virtualdub and the xvid codec are freeware)
    These cams are not ideal for low-light and could never compare
    to a cam with a huge low-f lens but for the curious here is the clip.
    www.ziddu.com/download/6616730/lltest2.avi.html
  • BeanBean Posts: 8,129
    edited 2009-09-24 21:43
    Holly,
    I have two of the CCD cameras and I'm having the same problem with them only connecting at USB1.1.
    If you find a way to get USB 2.0 speed out of them PLEASE let us know.
    P.S. I was able to record video until the memoy was full (a little over 1 hour). But it is taking just about that long to transfer the data to my hard drive.· Arrrrg...
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
    Post Edited (Bean (Hitt Consulting)) : 9/24/2009 11:04:10 PM GMT
    edited 2009-09-30 10:15
    I just got an order of 10 in from erco's supplier. I opened one up, and it looks very much like the one in the pictures on the first page of this thread.
    One thing I didn't notice until now is that the microSD card is in a position that you couldn't replace it without taking off the USB connector. I haven't tried that yet,
    Doug
    edited 2009-09-30 21:00
    An ugly and unconfirmed rumor: the micro SD card is easily removed and replaced in the 4GB units from Sinoit. The metal bracket holding it in is not a solid one-piece part, but has 2 arrow-shaped intentations that show how to unlatch the bracket to get at the SD card for upgrading or "harvesting" as Holly Harvester likes to say.
    I don't have my unit here to confirm, but a friend who got one of my Sinoit units just told me it was an easy swap for an 8 GB card. In the photos I posted on the first page of this thread, I do see the arrows he mentions.
    Hack freely, one and all!
  • iDaveiDave Posts: 252
    edited 2009-10-01 05:51
    Well....I sure am late to this party..and quite an interesting one at that! Coming across this thread is like opening a door to a room and seeing where all the cool kids r hangin out. LoL. Don't worry, I won't tell. Trying to digest the 4 pages of this thread has my head spinning kinda like Whit's head from Erco's video. The price of this thing is the showstopper. Okay...lets see..is this the one with the CCD (not cmos), microsd card or is this one horsepucky?!
    cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250501514232&ssPageName=STRK:MEWAX:IT
    "A complex design is the sign of an inferior designer."
  • jb1311jb1311 Posts: 20
    edited 2009-10-01 16:10
    The one from gadget.topseller88 is not CCD even though they say it is. It's 12.5 frames per second. Sound quality is OK.
    edited 2009-10-01 21:33
    IMO the only way to be certain of getting a good ccd cam is to buy 10 of them from sinoit.com
    or buy one from erco or someone else that got them from sinoit. Maybe it will cost you an extra 10 dollars
    compared to buying 10 at a time for 300.00 but the cams are well worth 40.00 I have seen them selling
    for 300.00 each at several security companies that supply gear to investigators.
    If you buy 10 of them you will soon discover that every geek that sees how well they work begs you to
    edited 2009-10-02 01:52
    Holly: Sounds like you're satisfied and probably going back for more! I'm sure you know more than 10 geeks... Did you swap out the micro SD card yet?
    edited 2009-10-02 02:08
    No, have not changed the 4gb unit yet, but nice to know the sd card
    I wonder if it can handle 16gb...
  • DVKDVK Posts: 1
    edited 2009-10-07 01:57
    This is content of firmware chip (W25X40) of "good" cam: http://rapidshare.com/files/289646153/808.rar.html
    Did you see strings "SETTIME.TXT" and "TIMEOUT.TXT" in there? [noparse]:)[/noparse]
    What it may be? [noparse]:)[/noparse]
    edited 2009-10-07 14:52
    DVK said...
    What it may be?
    I see those strings. Note that they are not identical to the hex representation of the
    file names SETTIME.TXT and TIMEOUT.TXT as the "." char is ascii [noparse][[/noparse]2E] but is replaced
    by ascii [noparse][[/noparse]20].
    But even so it seems to indicate that just as creating the file SETTIME.TXT with the proper
    contents and placing it into the root dir of the camera changes the time/date some similar
    result would follow the creation of the file TIMEOUT.TXT ????
    You could try creating a file named TIMEOUT.TXT with various data inside it to see what
    happens!? But it might have undesired results smile.gif You may know you succeeded if the file
    TIMEOUT.TXT has been deleted on re-boot...it also might be that files with these names are
    deleted from root dir on every boot whether they were successful in changing the cams settings or not.
    I also found two .bin file names... oddly the filename is separated from the .bin suffix by not one
    but two [noparse][[/noparse]20] chars ?
    ADJUST.BIN and CRESFW.BIN may be data files that if placed into the root dir would cause them to
    One of them might actually replace 808.bin as the contents of the mem chip in the camera.
    Playing may result in a bricked camera.
    I also found the string [noparse][[/noparse]RGBGain] ... it would be nice to be able to reduce the gain as the color
    saturation seems about 25% too high to me.
    Sure wish I had commented source for these cams....
    I keep googling for hack pages for these cams but with no result. If anyone finds a hack page please
    let me know.
    edited 2009-10-13 22:35
    @guardsmancobra from your PM:
    To set the time & date on a CCD camera ONLY (has the time stamp in orange letters on the bottom right of the image):
    Copy the attached text file into the root·folder of your cam. This is what shows up in "MY COMPUTER" as a removeable drive. The only other file in the drive is the DCIM folder. Modify the file to contain date & time info EXACTLY in that format. Set the time a minute ahead and save the file. It will·DISAPPEAR when it sets the time when you disconect the cam and take a quick vid within a minute (to keep your time data current). So I always save a backup·copy of this file inside the·DCIM folder to keep it handy. So the DCIM folder will contain the backup settime file and the 100DSCIM folder only.
    Note that the file must be called settime.txt and only contains EXACTLY 2009.10.07 00.19.00····· (updated)
    That's the date YYYY.MM.DD, a space, and the time HH.MM.SS
