Regen w/ motor mind B or HB-25
Hi all
does anyone know if you can perform regen using either the motor mind B or the HB-25 and if so can you point me to some example projects or code for the BS2
otherwise can some one point me to a controller that i can perform regen with and exaple projects and/or code for regen
thanks
CAB
thanks
CAB
any idea of a controller that is capable of regen?
CAB·
Don't worry. Be happy
thanks for the responses
i was looking and i found this thing
http://www.robotpower.com/products/simple-h_info.html
it says this in the user manual:
If regenerative braking of an inductive load such as a motor is desired it can be accomplished
as follows: when slowing or reversing direction supply a low duty cycle drive to the load until
the load has stopped or has reached a low RPM, then apply a brake or coast stop signal to
the unit. The low average applied voltage of the low duty-cycle drive will allow the inductance
of the load to boost the voltage at the battery terminals above the supply voltage and flow
current back into the battery. Unfortunately the current sensors will not read properly during
regeneration so the regeneration current level cannot be measured. Do not attempt
regeneration with a bench power supply only with a battery.
what do you guys think ?
thanks
CAB
Beau Schwabe
IC Layout Engineer
This one claims to be regenerative.
Sabertooth dual 25A regenerative motor driver.
Rich H
edit; Yeah, what Tim said, this is the same one.
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Post Edited (W9GFO) : 9/12/2009 5:20:17 AM GMT
Note: at the cost of raising the generated voltage to a charge level above the battery supply, you sacrifice current. This means that most of your charging is done in bursts or "pulse charging".
Beau Schwabe
IC Layout Engineer
what do you guys think of it?
does anyone have a link to some information on philosophy and integration of regen
or even generators in general so i can get a better idea of what i am up against
thanks again for all the responses
CAB
For general questions about electronics, try the Wikipedia. Do a websearch for "wiki electrical generator" and "wiki regenerative brake".
Couldn't you short the winding briefly, to build up the stored energy, then release it at a higher voltage through a diode back to the battery? This would be the same circuit topology as a boost converter.
Yes, that's typically how it's done, but the power source is considered part of the inductor or motor coil.
I don't have any reason to doubt that the sabertooth 'could' be doing that, I was just basically stating what really should be happening.
The posted circuit is regen in it's most basic form (a boost converter). The duty cycle at which you apply the braking signal determines how quickly you are going to stop or slow down. The frequency of the duty cycle is part of a feedback loop that monitors the output voltage. This circuit basically gets the voltage up and over the battery supply voltage, but you still need additional circuitry to take that voltage and correctly charge the battery chemistry that you will be using.
Note: If you have a motor controller that allows free-wheeling (motor free spin) , then a regen circuit 'could' be applied as an after thought to any motor controller that meets that criteria.
Beau Schwabe
IC Layout Engineer
What is the purpose of the diode on the far righthand side of your schematic?
"What is the purpose of the diode on the far righthand side of your schematic?" - Well it was intended for the mosfet protection, however... looks like the bridge is doing that at the cost of a diode drop. That should be sufficient. Even though by design, the mosfet transistor has a reverse biased diode, for this type of application I like to bootstrap it with an external diode.
Beau Schwabe
IC Layout Engineer
I am new to the board here, I just received my Viewport ULT + Prop Proto USB a couple of days ago and just fired it up. I have a Sabertooth 2X25 and hope to drive 4 wheel chair motors with two of them once I learn the basics. I would love a simple schematic of exactly how to wire my Sabortooth to the Propeller board, and just enough spin code (with tons of remarks) to turn the motors both ways at variable speeds. I have downloaded some of the objects for this from Parallax's website but it is still Greek to me. I am a hands on kinda guy and would learn fast with a little head start. I am building a very large Robot and am very excited about my new Propeller with its 8 cogs. I used to program in Turbo Pascal and went to Electronics school way too long ago, so I feel I have the basics. I just need a little jump start. If this request is way out of line for this board, just let me know and I will post a new thread begging for help;-P
wkinne
Beau Schwabe
IC Layout Engineer
The easy way is to generate a PWM (pulse width modulation) signal. I don't know Spin, but this should be a walk in the park. Go to the Prop forum to get help for this.
The 0V connection goes to Prop ground, and you could also power the Prop from the 5V output.
The PWM signal needs to be smoothed out, so you need an RC circuit on each of the outputs. This is explained in the documentation, with 10K and 0.1uF cap.
The motor will move in one direction when the PWM signal's RMS value is below 2.5V and in the other when it's above. Keep frequency above 1000Hz.
Another option is to use a digital potentiometer, but that's overkill compared to PWM.
