newbie question: Inline assembly?
I am attempting to optimize some of my code from Spin to Assembly.
I hit the books, and couldn't see any way to inline assembly within my spin method.· Nor could I find a way to call an assembly function stored in a DAT block, without spawning another cog to go execute that code?· Is this true?· Help!· I'm itching to make my code faster!
Thanks!!
··· Roger
Thanks!!
··· Roger
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Have your assembly cog looking for a one set in some long somewhere. When it sees it, it loads it's parameters and does it's thing, writing a zero when done.
Your parent cog watches for the 0 while doing it's thing.
Share data between the two with a block of longs in the HUB.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Not really a problem however as you have 8 cores. Use em.
Nyamekye,
*Peter*
Thanks to everyone!
Roger
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
As a new-comer you should probably look at learning PASM the way the Propeller manual describes to do it. A vast majority of PASM code is written that way (this of course includes "Spinning" in a command listener). What Ken suggests is a reasonable and simple method that is usable with normal PASM coding (beat me to the post).
Still, what you have suggested is possible and I do something similar to that in my PASM BMA debugger at some cost in terms of extra HUB memory used. I don't have to restart a cog to do it. Starting a COG takes about 102us at 80MHz (12.5*16*512). Basically, a stub for handling COG maintenance (COG server?) is loaded into a COG, and a Spin object (COG client?) manages what the COG does. A set of PASM instructions ending with a JMP #1 (the COG server reentry) can be sent to the COG as needed from any source (a Coglet?) and run there in real-time. The source is available if you want to have a look in my .signature BMA debugger link. File PASMstub.spin has most of the methods to manage the COG server; the "GO" feature that tells the loaded code to run is in BMAutility.spin for version 1.3.
The LMM or Large Memory Model (as Bill Henning originally called it) is another method which has lots of developer history. LMM is slower than run-time PASM, can run up to 8K longs vs 512 in a COG, and is a little different from PASM. LMM is slower because it uses a COG loop to grab and "interpret" LMM-PASM from hub memory. Since the LMM-PASM code lives in the HUB, near 8K (32KB/4B per instructions) of PASM can be used per program load. The LMM deviations from normal PASM have to do with the way jumps and data are handled and is a little hard to follow at first.
--Steve
Propeller Tools
Now...back to your Inline PASM conversation....
"I have not failed. I've just found 10,000 ways that won't work. "
- Thomas A. Edison
Ken, there is nothing short and fully comprehensive that I know of (because different people like different approaches).
Here are some wiki pages:
propeller.wikispaces.com/Large+Memory+Model
propeller.wikispaces.com/LMM+Phil+Pilgrim+(PhiPi)
propeller.wikispaces.com/LMM+Pacito
propeller.wikispaces.com/LMM+AiChip+Industries
Many people have written variations. ImageCraft produced one of the first widely used working implementations of LMM. Bill is morphing LMM into LAS (or has morphed it) which is supposed to make LMM less abstract. The original thread is here: http://forums.parallax.com/forums/default.aspx?f=25&m=154421
Hippy was I think the first to do several projects with LMM and I followed his work as examples. Here is an excerpt from Hippy's AI_Chip LMM version 1 (can't find the thread, but I believe there are later versions) which is an original and well thought description worthy of being included in a book (for royalties). Maybe someone will invite his participation some day.
' ******************************************************************************************************* ' * * ' * AiChip_LmmVm_001.spin * ' * * ' ******************************************************************************************************* PRI Version return String("AiChip_LmmVm_001") CON { This is a Virtual Machine (VM) which allows execution of Large Memory Model (LMM) programs. LMM programs are those which can be larger than the 496 longs allowed for by a Cog's memory limitation. This VM is designed to be easy to use with the Propeller Tool although it does necessitate some manual changes to use a Propeller Assembler program as an LMM program. This VM only supports user variables which are held within the executing Cog memory and the number of variables is an absolute maximum of 496 and will be lower than that because of the space taken up by the VM code itself. If the internal stack is used, the number of user variables is reduced further. The current LMM VM footprint is approximately 72 longs ( excluding debugging code ) and can be reduced to around 60 longs if conditional LMM instructions are not required ( LMM_Conditional removed ). There are therefore around 420 Cog memory locations available for user registers and internal stack. The following changes must be made to make a Propeller Assembly program LMM compatible - mov <reg>,<longConstant> jmp #LMM_Load long <reg> long <longConstant> jmp #<Label> jmp #LMM_Jmp long @<Label> jmp <reg> jmp #LMM_Jmp_Reg long <reg> call #<Label> jmp #LMM_Call long @<Label> jmpret <Label>_Ret,#<Label> jmp #LMM_Call long @<Label> ret jmp #LMM_Ret djnz <reg>,#<Label> jmp #LMM_Djnz long <reg> long @<Label> tjz <reg>,#<Label> jmp #LMM_Tjz long <reg> long @<Label> tjnz <reg>,#<Label> jmp #LMM_Tjnz long <reg> long @<Label> If any of the above need to be conditionally executed they should be preceded by 'jmp #LMM_Conditional' as in the following example ... IF_Z call #<Label> jmp #LMM_Conditional IF_Z jmp #LMM_Call long @<Label> The following Propeller Assembly instructions are not currently supported for LMM programs and must not be used - jmpret reg,reg djnz reg,reg tjz reg,reg tjnz reg,reg This VM uses a software stack rather than modifying 'ret' instructions as a genuine Propeller Cog program would. An internal stack is used by default which grows down in Cog memory from $1EF. When a large number of user Registers are defined care should be taken to avoid stack overflow corrupting registers, or an external stack may be used. If an external stack is required it should be enabled by using - jmp #LMM_Load long sp long <stackAddress> When an external stack is used, the stack will grow upwards in memory from the start of the array. To switch back from the external stack to the internal stack, use - jmp #LMM_Load long sp long 0 Stack swithing between internal and external can be done dynamically as required. Take care to return from the same stack as any call was issued upon. There is little, if any, discernable deterioration in performnce when using an external ( hub memory ) stack as opposed to the internal stack. Note that when converting 'jmp reg' the 'reg' should have been loaded with an '@Label' of where the destination jump will be to. For example, the following are equivalent - jmp #LMM_Jmp jmp #LMM_Load long @<Label> long <reg> long @<Label> : jmp #LMM_Jmp_Reg long <reg> The current LMM substitutions for Propeller instructions have been chosen to be easy to enter by hand and use within the Propeller Tool and these could be optimised. The 'jmp #LMM' commands can have an associated register embedded within the command ( as the unused destination register ) and two word arguments can be compacted as a single long. The consequence though is that any increased code density will be offset by decreased speed of execution. The VM code for LMM_Djnz, LMM_Tjz and LMM_Tjnz could be reduced to set the opcode bits of the required operation and make most of each routine common code and this would probably be worthwile if few of those instructions are executed within the LMM program. There is no overlay or 'block load and execute' capability in this VM. The VM is however very easily extensible to add overlays or other special VM instructions such as Push and Pop register. The major ommission in this VM is the lack of register indirect operations which cannot be achieved by using self-modifying code. Registers can be modified using movi, movd and movs but there is no 'execute register as an instruction' operation. It would be easy to add one, and provide Get Register Indirect and Put register Indirect instructions. LMM Instructions tested ... LMM_Load LMM_Jmp LMM_Jmp_Reg LMM_Call LMM_Ret LMM_Djnz LMM_Tjz LMM_Tjnz LMM Instructions not tested ... LMM_Conditional } } CON { PLEASE NOTE : If modifying and re-releasing this code, please change the prefix of the source file from AiChip so as to avoid any confusion as to the origin of the source and update all internal references as appropriate. If you wish to credit the orginal source, anything along the lines of, "Based on original AiChip_LmmVm_XXX from AiChip Industries", is acceptable. AiChip is a trademark of AiChip Industries. }A small performance enhancement done in ICC is to use "sub/add PC, offset" for jumps ... harder to read but faster.
Now, back to your regularly scheduled program ... brought to you by Ivory Soap!
--Steve
Propeller Tools
- Propalyzer: Propeller PC Logic Analyzer
- BMA: An on-chip PASM Debugger
- SPUD: Spin Source Level Debugger
Post Edited (jazzed) : 9/18/2009 5:47:44 PM GMTYes! I remember this now. Good for passing a parameter, return value, etc....
Funny how I used to think CALL was a separate instruction [noparse]:)[/noparse]
--Steve
Propeller Tools
