Propeller to Sabortooth 2X25 help please
I am new to the board here, I just received my Viewport ULT + Prop Proto USB a couple of days ago and just fired it up. I have a Sabertooth 2X25 and hope to drive 4 wheelchair motors with two of them once I learn the basics. I would love a simple schematic of exactly how to wire my Sabortooth to the Propeller board, and just enough spin code (with tons of remarks) to turn the motors both ways at variable speeds. I have downloaded some of the objects for this from Parallax's website but it is still Greek to me. I am a hands on kinda guy and would learn fast with a little head start. I am building a very large Robot and am very excited about my new Propeller with its 8 cogs. I used to program in Turbo Pascal and went to Electronics school way too long ago, so I feel I have the basics. I just need a little jump start.
wkinne
wkinne
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 MtrCtl = 0 ' Motor control pin { wire up motors and battery per instructions wire ground on prop board to 0 volts on Saber wire MtrCtl pin to S1 on Saber (perhaps with a 1kOhm resistor for safety) set 9600 baud on Saber per manual } OBJ Sio : "Simple_Serial" VAR ' Pub Main Sio.Init(-1, MtrCtl, 9600) Sio.tx(1) ' Motor 1 full reverse Sio.tx(128) ' Motor 2 full reverse waitcnt(clkfreq * 5 + cnt) ' wait 5 seconds sio.tx(32) ' Motor 1 half reverse sio.tx(160) ' Motor 2 half reverse waitcnt(clkfreq * 5 + cnt) ' wait 5 seconds sio.tx(64) ' Motor 1 stop sio.tx(192) ' Motor 2 stop waitcnt(clkfreq * 5 + cnt) ' wait 5 seconds sio.tx(127) ' Motor 1 full forward sio.tx(255) ' Motor 2 full forward waitcnt(clkfreq * 5 + cnt) ' wait 5 seconds sio.tx(0) ' Both motors stop ' WARNING rapid changes in power with large motors/driven objects with large inertia ' may cause damage. I don't know if the above changes in power are too much too fast WARNING ' I do not know if the Sabortooth will see 3.3 Volts as high, most but not all five volt devices do.John Abshier
OK, so you are saying one I/O pin from the Propeller will run one motor, 4 pins, 4 motors, right?
I love the test code and the object (which I had already down loaded) I do have a couple questions if you guys don't mind.
The test code I understand, thanks! The object I have no idea how I enter the PWM(0,1500), when I look at the code I see PWM asking for 3 inputs, pin number, on time, off time. What am I missing.
Also can other objects send this info to that object? I assume that is already written into the code to be passed that kind of variable?
Thanks again guys, this looks easier than I ever dreamed.
wkinne
I think I have enough info to get started, Sweet!
OK, I'm slow but I am remembering things lol, I see the demo calls he PWM object, I am starting to see the light LOL
Thanks again.
wkinne
Post Edited (wkinne) : 9/18/2009 10:54:04 PM GMT
