Another use for djnz — Parallax Forums
AlsowolfmanAlsowolfman Posts: 65
edited 2009-09-18 22:43 in Propeller 1
There have been a number of posts where people are using djnz to decrement a pointer, and i thought i would try taking this a little further(sorry to anyone who may have come up with this before me). One can use the line:
djnz :loop, #:loop
to jump and post decrement the source register. one can use the following two instructions to find whether an array in cog memory contains a value (a)
:loop cmp a, 0-0 wc, wz
if_b djnz :loop, #:loop
this first executes the compare between a and whatever address is loaded into 0-0, then it decrements the address( after, due to pipelineing), and then executes the compare between a and the register with the next lowest index.
This does not have that many uses where it would be beneficial, but i am using it in a a cog that has 4 nested loops that each run up to 80 times, so a single instruction can add seconds to the completion time.
some things that make this harder to use are:
- the array must be loaded in with the first data point having the highest address
-once it has completed its operations one must use the movs instruction, and add one to find the address that contained the correct data.
Here is some working demo code for it that turns pin 5 high to demonstrate that it works:
CON
  _clkmode      = xtal1 + pll16x
  _xinfreq      = 5_000_000
pub main
cognew (@work,0)
repeat
dat
org 0
work          movs :loop, #:d   'this gives the address after the main array
              nop
              djnz :loop, #:loop    ' this jumps past the data, it is necessary to start with a djnz so the first cycle is not repeated twice
              long 0           ' this fulfills the condition in :loop, and prevents it from doing strange things
              long 1,2,3,4,5,6,7,8
:d            long 9
     if_b    djnz :loop, #:loop   ' this works as a jump and post decrement the source register operation
              movs b, :loop
              add b, #1   ' this corrects for the post decrement of :loop
              cmp b, #3 wz, wc    'these two lines verify that it has not stopped due to the zero at the end
        if_e  jmp #noend
              movs :loop2, b
              nop
:loop2        mov c, 0-0   ' this retrieves the number from the array
              mov b, #1
              shl b,c
              mov dira, b
              mov outa, b
noend         jmp #noend   ' prevents execution of further data
a long 5
b long 0
c long 0
I hope this helps someone, or is at least interesting.
Post Edited (Alsowolfman) : 9/16/2009 9:25:21 PM GMT
  • KyeKye Posts: 2,200
    edited 2009-09-16 21:34
    Nice find, Post this to tricks and traps of you find that tread.
    Nyamekye,
  • ericballericball Posts: 774
    edited 2009-09-16 23:33
    Okay, I finally grok what you're doing.· In your specific case both djnz parameters are the same label, but that doesn't have to be the case.
    ; In general terms you can use
      IF_<cond> DJNZ ind_src, #looptop
    ; instead of
                SUB  ind_src, #1
      IF_<cond> JMP  #looptop
    In your case, where the two labels are the same you have to put an extra step to handle the pipeline delay.
    The question is whether reverse indexing your data is worth 4 bytes & 4 cycles.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    edited 2009-09-17 06:08
    Ah, now this could be used in comparing two buffers for equality/inequality.
    For example, in ZiCog we write data to the SD card. Now, I suspect quite often, the write will be to the same sector as just read. Anyway, we are blocking the sectors, so we have to re-read the block before writing anyway. Now, if we compare the 128 bytes that we are writing with what we just read, we could determine if a write is required. We only have to compare until the first byte of inequality. Actually, we can actually compare 4 bytes at a time by using longs. Food for thought smile.gif
    BTW a similar technique is used in my overlay loader which came from Phil's??? original work in reverse LMM.
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
  • AlsowolfmanAlsowolfman Posts: 65
    edited 2009-09-18 17:49
    kye,
    ok, i posted it to tricks and traps, good idea.
    ericball,
    yeah, it has a lot of shortcomings, but it is the fastest way that i have found to search a large array in cog memory.
    cluso99,
    It sounds like you are comparing the same bytes in each array, a[noparse][[/noparse]0] to b[noparse][[/noparse]0], and a to b... , i think it would be best to use the add #1_000000001 trick instead. this is more useful if you are trying to find if any two longs in any part of the two arrays meet some criteria ie, a[noparse][[/noparse]0] to b[noparse][[/noparse]0], a[noparse][[/noparse]0] to b... a to b[noparse][[/noparse]0]... to use this trick you would have to change the destination register every loop as well, so it would take 3 instructions, and be very confusing.the add #1_000000001 trick would only take you 3 instructions and you would not have to store everything backwards.
    yeah, this is based on the reverse LMM method, i was trying to give credit in the first line, but i guess i should have been more explicit. i started with the idea from that of using djnz to decrement a pointer from the reverse LMM method, and instead use it to decrement the source register directly.
    ***add #1_000000001 trick in case people have not seen it(i did not come up with this)
    :loop cmp a,b wc, wz
    add :loop, c
    if_e jmp #:loop
    c long #1_000000001
    this adds one to both the source and destination registers in one action
  • jazzedjazzed Posts: 11,803
    edited 2009-09-18 18:10
    @Alsowolfman,
    One of the problems ericball mentioned is in these two lines from your first post:
    This will not work without an instruction before cmp. You have to fill the pipe.
    Edit: What was I thinking? Another broken fragment removed [noparse]:)[/noparse]
    --Steve
    Propeller Tools Post Edited (jazzed) : 9/18/2009 6:33:33 PM GMT
    edited 2009-09-18 18:58
    this code is designed around the pipeline, from desilva's tutorial the pipeline works as follows:
    CURRENT instruction
    LAST/NEXT instruction
    T=-1:
    Fetch "source" for LAST operation
    T=0: Fetch Instruction
    Perform LAST operation
    T=1: Decode instruction
    Store result back into "dest"
    T=2: Fetch „dest“ operand
    T=3: Fetch „source“ operand
    T=4: Perform operation
    Fetch NEXT instruction
    T=5: Store result into "dest"
    Decode NEXT instruction
    T=6:
    Fetch "dest" for NEXT instruction
    the first time that the cmp is used it executes using the source that is originally there, while it is preforming the cmp the new source address is written. when it loops back to the cmp the second time it retrieves the address put there by the first djnz, and while it is preforming that cmp, it changes the address again...
    this does work, test the code, it should pull pin 5 high.
    jazzed said...
    @Alsowolfman,
    Yes and no.· Having the source & destination the same just means the decrement doesn't take effect until the next time through the loop.· Alsowolfman handles this by invoking djnz :loop, #:loop to enter the loop.· So the first execution of ":loop" uses [noparse][[/noparse]src], the second [noparse][[/noparse]src-1] and so on.· Without the initial djnz, [noparse][[/noparse]src] would get used twice.
    edited 2009-09-18 19:12
    Ok. Sorry I mentioned you eric, but I interpreted this "In your case, where the two labels are the same you have to put an extra step to handle the pipeline delay." to mean the same thing as I was thinking.
    Granted, the cmp instruction source 0-0 at :loop is post decremented. Why is #:loop in the djnz instruction decremented before the jump happens?
    --Steve
    Propeller Tools
    edited 2009-09-18 19:42
    i don't think i understand you question, #:loop, the adress of :loop in cog memory, is stored in the djnz instruction, and is never changed. the cmp and djnz commands repeat until the condition if_b is no longer satisfied.
    Yes, it occurred to me after I left for my shopping trip that #:loop would never change since it is a constant.
    The djnz loop is no different (except that it's a loop) from the following which will always throw a flag for me.
           movs chgsrc, ndx
    chgsrc mov  dst,    0-0
    In this case dst will not get the content pointed to by the ndx value unless there is something in the pipe.
    So, you are relying on the previous value of the source in "cmp a, source wc,wz" to be the old value. Mmm, OK.
    Looks like a good trick, and it's nice to have a fresh tool in the box, but I would have to put a big fat comment
    on it to keep from getting confused.
    --Steve
    Propeller Tools
