2 stamp 2s connected
I have 2 stamp 2s connected together the second one counts sheets of paper on a printing press the first is connected to a pc via the serial port on a requst from the pc the first stamp interrupts the counting and gets the total.
This works fine but only when the counting stamp is connected to a debug terminal. If the·debug terminal is disconnected·it·fails intermittently.
Can someone please·help.
·Regards
Desz
Post Edited By Moderator (Joshua Donelson (Parallax)) : 10/23/2009 3:27:35 PM GMT
I have 2 stamp 2s connected together the second one counts sheets of paper on a printing press the first is connected to a pc via the serial port on a requst from the pc the first stamp interrupts the counting and gets the total.This works fine but only when the counting stamp is connected to a debug terminal. If the·debug terminal is disconnected·it·fails intermittently.
·Regards
Desz
Welcome to the forums. Please always use a descriptive Subject.
If I understand you correctly, if only one stamp is used (the counting stamp), the count is shown correctly on the debug screen and when the communication link is used it "fails".
I suspect the actual failure is due to having the multiple devices trying to do their own thing without regard to what the others are doing. As an example, as the counter is counting, it cannot really be interupted until its gets to its SERIN command and actually hears the other stamp asking for an update. Similarly the Stamp at the PC will not hear the PC unless it is actually sitting on the the SERIN when the PC requests an update.
Some of these issues can be overcome with better handshaking and taking advantage of the fact that the PC has a comm buffer and therefore can receive data anytime.
Show us the connections you're using and I'm sure you'll get some more things to check.
Cheers,
Tom Sisk
http://www.siskconsult.com
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
