Parallax's New Wheel Kit--What could it mean?
Hello everyone, I just saw the new wheel kit that was released, and those wheels look VERY much like the ones of this...· Does this mean that a new bot is coming along...?· If so, then it will most definitely be expensive, as those wheels alone are $100...
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Quality products, such as what Parallax offers, do not come cheap. In the world of robots you generally get what you pay for. Be patient and save your money. A good quality robot is better than a bunch of cheap ones that you are always having to repair.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Similar to the Motor Mount and Wheel Kit, this is a real top-quality product made in our Rocklin office on our Haas CNC machines. No expense is spared when it comes to our robotic hardware - we want people to have hardware that works well and holds up. The aluminum is machined, tumbled, anodized and packed to prevent scratching.
As far as the expense for this specific product, here's a little business lesson that would be appreciated by anybody who manufactures and sells products:
Labor cost 3.48620
Material cost 31.84318
Fixed overhead 6.97130
Variable overhead 0.00000
Sub contract cost 0.00000
Total cost 42.30068
This is our cost of manufacturing (parts, material, screws, wheels, motors), including manufacturing labor (the cost of the CNC operator's labor, per unit). This excludes overhead required to support the product, such as salaries in marketing, editorial review, technical support, engineering (these numbers do not include the engineering NRE, which could be $10-20K). At initial glance, you'd think "wow! Parallax makes $58/unit on those kits!". But, in reality, it's among the lowest margin any sensible company would accept for what is considered a low-volume product. The return on investment is probably around 500 units.
My point (and I realize nobody is complaining) is that $99 is a real deal for such a kit. In the end products like this barely support a USA machine shop. Our machining services aren't designed to make money on their own, but to supplement and inspire other purchases in motor controllers, sensors, microcontrollers, educational books, etc.
I promise that you'll be happy with any machined product from Parallax. We absolutely refuse to make low quality stuff at the benefit of a profit, and we'll use expensive manufacturing processes to deliver some really nice designs. If we were about profit, this motor mounts would be made from sheet metal, punched and then shaped on a brake.
BTW, this kit also fits with our 28971, Caster Wheel. They're both designed to mount under your robot base. Give this kit a try and return it if you are not more impressed than you expected to be. We'll take care of your desires to be happy with our products no matter what they are, I promise.
Parallax Inc.
I think the point of this thread was greatly misinterpreted. I only meant to ask whether anyone knows whether there are any updates on the robot talked about in the thread I linked, and whether this kit could be the same wheels used in the "stingray"...
PG
But back to your question and the reason for your post, which I didn't answer. This product is using Stingray motors and wheels. The motor mounts are not used on the Stingray, however.
Stingray will be out in a few weeks at this point, at less than $300.
- Ken
Since you're stating zero for subcontract cost, does that imply that you do your own tumbling and anodizing, too? Or am I misunderstanding something in your post?
Yes on the tumbling. We added that capability in the summer.
You're right about the anodizing costs - they should show up under "subcontract". I'll have to look into that a bit, but it's additional costs for which we have not properly accounted.
- Ken
I can hardly wait... ·I will start saving now! This is the only reason I haven't ordered the new motor and wheel set. I want on of the Stingrays. I am glad they will work with the caster wheel too - Is that what the final stingray will use or will it be as previously pictured (i.e., with the omi-directional wheel)?
Thanks for asking about this Vaati and thanks Ken for letting us know what goes in to making these.
Whit+
We do not carry the encoders, but we have tested them to work with these motors. The ones with the sticky back can be tricky though to get good alignment since the motors have text on the plastic which can throw alignment off a bit. You just need to make sure it is even and you should be good to go. Later after the initial release we will visit the encoders and most likely create some sort of AppNote and object for dealing with them. Take care.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
Chris Savage
Chris Savage
What tripped me up is that the rear shaft doesn't turn at the same speed as the output shaft. The encoders I have give 100 cpr. In my case, the 30 x gearing of the motors I'm using equates to 3000 counts per revolution. This goes up to 12,000 counts at full quadrature. No wonder my distance routines weren't working!
You might rightly think "well DUH!", but the effect of the higher speed of the rear shaft isn't mentioned in any sales literature for the encoders or the motors.
Other than that, the stick-on encoders work well and I'm quite happy with the increased resolution!
The 7.2V Motor, Bracket and Wheel Kit is now &79.99! What a deal! See Ken's post above.
See - http://www.parallax.com/Store/Robots/AllRobots/tabid/755/ProductID/587/List/0/Default.aspx?SortField=ProductName,ProductName
Whit+
Chris Savage
