i2c help
So I am learning how to use an i2c bus and I am embarrassed to admit that I cant seem to find my Ic's Slave Address. The device is a M41t0 RTC and the data sheet is
www.st.com/stonline/books/pdf/docs/9105.pdf
I am not sure but I think that the address is D0 hex. Could someone be so kind to verify this and help me with further questions while I attempt to learn?
Post Edited (Zap-o) : 9/17/2009 2:07:58 PM GMT
My next question is : If the Eeprom on the prop board is connected to another i2c device wont the propeller tool programmer not place the code on the propeller when using 2 pull up resistors? If i recall I used two pull up resistors in the past and noticed this problem. Currently I use 1 pull up.
prop pin (scl/sda) has 10K resistor to 3.3V, then a 1K inline resistor,then a 4K7 resistor to 5V
3.3V volt I2C devices connect to the prop side of the 1K inline resistor
5V I2C devices connect to the farside (away from prop) of the 1K inline resistor
Heres the circuit drawn in spin
