5MB/s Propeller to Propeller Data Transfer with 9 Bits
dat '{ '----------------------------------------------------------------------------------- ' 5MB/s Propeller to Propeller parallel bus transfer is possible using bits P[noparse][[/noparse]0:8] ' This requires $1xx on P[noparse][[/noparse]0:8] for continuing transfer and $0 to stop. ' A pull-up is used on P8 to control the transfer (pullup because rdbyte 0-extends). ' Use djnz and comparisons to do pointer decrement. ' These are code fragments illustrating the principle and will not compile as is. '----------------------------------------------------------------------------------- ' Read Propeller/COG ' readprop org 0 ' all bits start as input mov t0, #0 ' make sure all bits are clear mov ptr, addr ' set the base address add ptr, len ' add the length :read movs t0, ina wz ' looking for 0 on all bits and P[noparse][[/noparse]0:8] wrbyte t0, ptr ' write to ptr = address + length if_nz djnz ptr, #:read ' if t0 <> 0, continue with ptr-1; else stop '----------------------------------------------------------------------------------- ' Write Propeller/COG using djnz pointer ' writeprop org 0 or dira, #$ff ' P[noparse][[/noparse]0:7] are outputs, P8 starts as input mov ptr, addr ' set the base address add ptr, len ' add the length andn dira, #$100 ' start write ... bit 9 is pulled high externally :write rdbyte outa, ptr ' get byte from djnz controlled pointer cmp ptr, addr wz ' test for end condition if_nz djnz ptr, #:write ' if ptr > addr, decrement pointer and repeat andn outa, #$1ff ' clear bits or dira, #$100 ' signal finished with bits[noparse][[/noparse]0:8] == 0 '----------------------------------------------------------------------------------- ' Write Propeller/COG using more familiar pointer decrement, djnz len method ' write2prop org 0 or dira, #$ff ' P[noparse][[/noparse]0:7] are outputs, P8 starts as input mov ptr, addr ' set the base address add ptr, len ' add the length andn dira, #$100 ' start write ... bit 9 is pulled high externally :write rdbyte outa, ptr ' get byte from djnz controlled pointer sub ptr, #1 djnz len, #:write ' jmp if dec len > 0 andn outa, #$1ff ' clear bits or dira, #$100 ' signal finished with bits[noparse][[/noparse]0:8] == 0 '----------------------------------------------------------------------------------- '}
I considered a similar idea using PHSA, but found using PHSA as a pointer to be impractical.
--Steve
Propeller Tools
I was thinking of something similar, but was considering 10 pins (separate REQ/GRANT).
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
--Steve
Propeller Tools
