indirect addressing in assembly?
I'm trying to do something new (to me) in assembly. I have a table of bytes I wish to get the address of to begin to pick up values for a D/A.
Looking at what's happening in PASD, at ':dloop' I get an address of 68BE4AFD, yet that location is 01B!
I'm obviously something is not proper here. Anyone got a clue?
Harley Shanko
DAT org 0 '
entry ' --- Debugger Kernel add this at 'entry' --- MUST BE LAST COG IF USE 'PASD'
long $34FC1202,$6CE81201,$83C120B,$8BC0E0A,$E87C0E03,$8BC0E0A
long $EC7C0E05,$A0BC1207,$5C7C0003,$5C7C0003,$7FFC,$7FF8
D2A or DIRA,DAmsk ' make A16.A19 outputs
or OUTA,DAmsk ' and at HI level
mov indx,#15 ' set for 16 samples
:dloop mov tmp,@D_A
add tmp,#15
sub tmp,indx
mov tmp,@tmp
mov wait,D2Ams
add wait,cnt
waitcnt wait,D2Ams ' wait for next sample time
xor tmp,OUTA ' alter just D2A pins
xor OUTA,tmp
djnz indx,#:dloop
jmp #D2A ' run forever
' Initialized data
D_A BYTE $02,$06,$0E,$0F,$0A,$03,$00,$03,$02,$02,$02,$02,$02,$02,$02,$02
D2Ams LONG 5_000_000 ' for 16 samples at 60 bpm
DAmsk LONG $000F_0000 ' uses pins A16..A19 for D/A
' Uninitialized data
indx RES 1
wait RES 1
tmp RES 1
Harley Shanko
In order to do indexed addressing in PASM you have to use self-modifying code. PASM has statements especially for this that make it easy.
For a good tutorial on PASM, check out deSilva's excellent Machine Language Tutorial
http://forums.parallax.com/showthread.php?p=668559
Ken
P.S. Chapter 5 in the tutorial is where you'll find info you need.
Post Edited (Ken Peterson) : 9/15/2009 7:01:47 PM GMT
Nyamekye,
Is there a a short, concise description of what one has to do to accomplish what's needed for self modifying code. To me deSilva's document is great, but think he didn't complete what he started on pg 21. Certainly didn't describe sufficiently for someone who'd never worked with such code.
D2A or DIRA,DAmsk ' make A16.A19 outputs or OUTA,DAmsk ' and at HI level mov indx,#15 ' set for 16 samples :dloop mov tmp,#D_A ' get address of D_A array add tmp,#15 ' add offset to array end sub tmp,indx ' subtract indx value movs tmp2,tmp ' get value at pointer tmp nop mov tmp,#tmp2 nop shl tmp,#16 ' position to D/A pins mov wait,D2Ams ' add delay count (2 ms) add wait,cnt waitcnt wait,D2Ams ' wait for next sample time xor tmp,OUTA ' alter just D2A pins xor OUTA,tmp ' plus add system counter value djnz indx,#:dloop jmp #D2A ' run forever ' Initialized data D_A BYTE $02,$06,$0E,$0F,$0A,$03,$00,$03,$02,$02,$02,$02,$02,$02,$02,$02 D2Ams LONG 5_000_000 ' for 16 samples at 60 bpm DAmsk LONG $000F_0000 ' uses pins A16..A19 for D/A ' Uninitialized data indx RES 1 wait RES 1 tmp RES 1 tmp2 RES 1▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Harley Shanko
:dloop mov tmp,#D_A add tmp,#15 sub tmp,indx movs :moveIt,tmp nop :moveIt mov tmp,0-0 shl tmp,#16The "0-0" is just a placeholder. By convention, that implies that the instruction field will be modified somewhere else in the code.
Perhaps this might make some since... another problem outside of needing to create self modifying code, your 'D_A' table is setup in BYTES
The line that reads...
...is justified in LONGS, and thus reads an entire long.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 PUB start cognew(@D2A, 0) DAT org 0 ' D2A or DIRA,LEDs ''------------------------------------------------------------------------------------------------------------------------------------------ ''The next 4-lines of code self modify ':dloop's Source register ''------------------------------------------------------------------------------------------------------------------------------------------ movs tmp, :dloop '<-Indirectly read the address of D_A through ':dloop's Source redister add tmp, #1 '<-Increment to appropriate position ; LONG justified ; for this demo, try a 1 or 0 here movs :dloop, tmp '<-Self modify ':dloop's Source register to point ot new location nop ''------------------------------------------------------------------------------------------------------------------------------------------ :dloop mov tmp, D_A '<- Even though D_A is defined as BYTE, this will read the entire long 'into tmp as little Endian ''------------------------------------------------------------------------------------------------------------------------------------------ ''Unremark one of the next 4-lines at a time to 'see' what's happening with the Demo Boards LEDs ''------------------------------------------------------------------------------------------------------------------------------------------ 'ror tmp, #8 '<- Moves 'D-Byte' of D_A, 8 places to the RIGHT to align with DEMO Board-LED 'C-Byte' 'ror tmp, #0 '<- No alignment necessary here 'C-Byte' of D_A already aligned with DEMO Board-LED 'C-Byte' 'rol tmp, #8 '<- Moves 'B-Byte' of D_A, 8 places to the LEFT to align with DEMO Board-LED 'C-Byte' rol tmp, #16 '<- Moves 'A-Byte' of D_A, 16 places to the LEFT to align with DEMO Board-LED 'C-Byte' ''------------------------------------------------------------------------------------------------------------------------------------------ mov OUTA, tmp NoEnd jmp #NoEnd ' Initialized data ' LSB-long <--------Long 1--------> MSB-long LSB-long <--------Long 2--------> MSB-long ' A-Byte B-Byte C-Byte D-Byte A-Byte B-Byte C-Byte D-Byte D_A BYTE %11001100, %10101010, %00111100, %11110000, %01100110, %01010101 , %11000011, %00001111 ' MSB-long LSB-LONG ' D-Byte C-Byte B-Byte A-Byte LEDs LONG %00000000_11111111_00000000_00000000 ' | | | | | ' P31 P23 P15 P7 P0 tmp res 1▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 9/16/2009 2:29:30 AM GMT
Have a look at Mike Green's post Posted around 8/23/2006 or 8/22/2006 (look about two thirds the way down the page) at:
http://forums.parallax.com/showthread.php?p=601870
This shows how to do do table look-up in PASM cog RAM; bytes as well as longs [noparse][[/noparse]note the comments and lines commented at the end with (*)]. Mike's post may provide some insight. Also 0-0 is apparently legacy nomenclature from assembler in early IBM machines. It means the "here" PASM address, which is actually the $ character in the latest prop manual. so you may use something like $-$ instead. But 0-0 is prolific in propeller example code, so my recommendation is to stick with 0-0. There was a short thread about this 0-0 thing I started not too long ago not knowing what 0-0 was with excellent feedback; but I can't find the URL right now.
Regards, David
When there's time I'll need to look into the references to self-modifying code. Sounds like magic, slight of hand as a newcomer to such coding.
Harley Shanko
