Forum Archive. Coming Soon. Need Programer Help/Sugestions
I have goten the go ahead from Parallax to download the entire forum. I will be doing this January 1st, 2010.
I will be compiling the data into a DVD or multiple DVD images that will be available for free download.
I can easily write the spider to download all the text and files publicly viewable on the forum the question is what is the best format to store them on DVD?
HTML would make finding what you want difficult. There will need to be some kind of search method.
Anyone up to writing a program to put on the dvd to display, sort, and search the large amount of data there will be?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
With attached files?
I'd consider .torrent transfer for this, at least initially to save on bandwidth. (I'll seed)
OBC
New to the Propeller?
Excellent idea btw - it will let me take the forum with me on future cruises!
(They charge$55US for 100 on NCL)
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I definitely plan to download all attachments.
DVDs will definitely be via torent and my web site. I am not woried about bandwidth but will be faster via torrent to send to many people.
( Pretty Demented Format )
The only advantage to this format is that it's hard to search, hard to (really) use, and dang slow. Making the threads available for the slowly growing number of folks using E-readers is the *only* reason I can conjure up for PDFs.
Stick with HTML.
Slurp the whole site into a mambo PERL routine and spit HTML out the other end...
Will there be any "clean up" efforts? ... i.e. there are some images saved as 24-bit color, when only two colors are used in the drawing.
Depending on how the image data is referenced, you could use a batch image converter to save a huge amount of space.
Beau Schwabe
IC Layout Engineer
I can save all the data in any format.
Html would definetly make so any os can read.
Still relatively easy to render or link to from search program.
If you flatten the posts into some output format (HTML, PDF, DOC), you may encounter undue difficulties trying to retrieve the original information from the posts, as they are now flattened and some of the original data-structure might have been lost.
And will ask parallax if they would consider letting me have direct dump of appropriate tables
that would make sense as the beasty was built by 'dotNetBB' - and SQL server usually is a tad more.
[noparse][[/noparse]EDIT]
Actually info via the link at page bottom indicates SQL 2000.
You'd need an ODBC connection if you really want to do this easy... but that's somewhat of a security hole.
Post Edited (CounterRotatingProps) : 9/15/2009 9:55:36 PM GMT
Is this also a preliminary step to replacing the forum software?
One thought: first, generate an index. Then provide the index in something that can be used in Javascript. Do the UI and search functions in Javascript and then nothing needs to be installed from the DVD.
"I have not failed. I've just found 10,000 ways that won't work. "
- Thomas A. Edison
this way you can make a simple, web like HTML entry point.
(I'm in a similar situation as Ken, but can at least offer ideas.)
lt's not particularly silly, is it?
Ah, *what* would be multiple emails ?
The data Parallax is sending you, or the search fetch results back to the user?
> How many programs will give useful results from 10000 html files. Would be easiest to save as 1 html per thread
Not sure where you're headed there, Matt, but there's a reason why this thing is in a DB in the first place... I'd say the easiest way to do this is to forget the DVD idea and just set it up as a static image on your server.
Since·you have access to a server, can you put SQL-server on it?· If you can't (do to $)·SQL can usually be converted to MySQL.
Either way,·the simplest thing: just snapshot the existing tables from the Parallax DB and replicate the database on your server, then make a simple web front-end to it.· Let the DB do the indexing, searching, etc.
This could be coded, moved, and launched in a matter of hours.
I will keep image on my server indefinetly so losing do to damage disk not a problem.
I have a mysql server but purpose is offline use. Use parallax for online.
On blackberry. Not sure what word email was suppose to be.
Database is probably not that big. Attachments are probably very big.
The question is best format for static dvd.
1 folder per forum
1 html file per thread
Coma delimited index of key raises for script to help find thing.
Or keep entirely database with code for each of the major os
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
FIRE GOOD !
Html or database
Html I can do by myself(look almost exactly like this site but with no option to write stuff, and no search feature). I would like to be able to package a program along to help in finding stuff.
Database I need help. there would need to be 3 programs to interpret. 1 for each of the os's
Post Edited (mctrivia) : 9/16/2009 12:49:41 AM GMT
Other then search database format does not provide much benefit and would force pc to generate page.
I think html for the majority of data with a coma delimited database for search purposes would be best. Any os can read html and even if no one writes code to use db by release it could be installed on pc afterwards.
