BS2 as button??
hi... lemme see if i can ask this properly...
i have a circuit that has a play button (lil mini voice recorder)
how would i have that triggered by my bs2??
thanks for the help...
RadioShack carries some 5V coil voltage reed relays that would work just fine. They also have the switching transistors, diodes, and resistors you'd need.
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv6.pdf
Post Edited (Mike Green) : 9/15/2009 3:53:48 AM GMT
what about something like a 4066 chip...would that work.....i think they work something like ....send a digital out to the chips control pin...and that will make make an analog type switch connection?
or am i totally wrong with that !??!?
thanks again
VERY much appreciated!
Note that this will not work with a BS1 Project Board or BS2 Homework board. They have series protection resistors on all their pins.
I know I'm in the minority here, suggesting this direct connection to the stamp. I have used such a circuit a lot and it works reliably if you hook it up right. If you get it wrong, you can·smoke at least one Stamp pin. I like it because it's·the minimum parts solution and fastest. For beginners, fewer parts & connections is a good thing IF they get it right·the first time!
"A complex design is the sign of an inferior designer."
Don't worry. Be happy
