Wireless BASIC Stamp Communication using 2-meter HT Radios — Parallax Forums
edited 2009-09-16 12:15 in Robotics
Interfacing the RTX-12 Modem to a BASIC Stamp
Wireless Communication for Microcontrollers using HT Radios
General Description
The Tigertronics (www.tigertronics.com) RTX-12 Radio Modem and a set of 2-meter handheld radio transceivers offer a functional solution for long-range data transmission between microcontrollers. With 5W power on standard 2-meter handheld radios it is quite·easy to send data several miles or many more depending on antennas and line-of-sight, and whether or not repeaters are used. In this project we were able to send and receive valid data packets at a distance of three miles using 5W radios and HT antennas.
You must have an Amatuer Radio License (available through www.arrl.org) to try this project, though you could also attempt the same using the Family Radio Service radios if they have mic/speaker connections.
This example uses the BASIC Stamp, though it may be substituted with any microcontroller. The example includes two sets of programs: a simple version that lacks error checking and a more complete example with checksums.
The reason I am experimenting with this project is because I plan on porting it to the Propeller for use in my outdoor robots for telemetry. Specifically, this platform: http://forums.parallax.com/showthread.php?p=654636.
Required Parts
  • (2) RTX-12OEM Radio Modems (Tigertronics #RTX-12OEM)
  • (2) BASIC Stamp 2 Modules (Parallax #BS2-IC)
  • (2) Super Carrier Boards (Parallax #27130) or other project area
  • (2) Amateur Handheld Transceivers (Yaesu #VX-6R used in this example though a variety of HT models are suitable)
  • (2) Radio Adapter Cables (Yausu #CT-91 for the above radio)
Schematic
Use the same schematic for transmitter and receiver. The receiver BASIC Stamp will be connected to your PC for DEBUG.·
Hardware Setup
Below are some general suggestions about the hardware setup:
  • Two duplicate setups are required to run the sample programs; the schematic is the same for the transmitter and receiver. The receiver will remain connected to the PC via serial or USB cable to display data from the transmitter.·
  • Tigertronics offers a ribbon cable to easily connect to their RTX-12. We suggest you purchase this cable since connecting to the RTX-12’s individual pins can be difficult without it. Tigertronics provides only one end of this cable terminated with the connector. You will need to locate some female 2x5 IDC connectors to wire the cable to your microcontroller.
  • 2-meter HT radio manufacturers have vendor-specific cables to connect the mic and speaker port. The mic is commonly a 2.5mm cable and the speaker is 3.5mm. These are often joined for a single connection to the radio.
  • You will need to make a cable to connect the radio’s mic and speaker cable to the microcontroller project board. These are both mono cables, available from RadioShack and other electronic suppliers.
  • Critical attention should be paid to wiring. Diagnosing problems between the modem, radio and BASIC Stamp can be quite tedious if mistakes are made to the wiring.
  • Tune both of your radios to the ARRL’s 2-meter “miscellaneous and experimental modes” of 145.50-145.80 (MHz). Set your radios to the lowest power mode necessary for transmitting and receiving.
Example PBASIC Programs
The RTX-12 Simple Transmit.BS2 and RTX Simple Receive.BS2 programs have no checksums or other error checking built into them. They are only provided to check your setup. To test them, program one setup as a transmitter and disconnect. Program the other setup as a receiver and leave it connected to the PC. Press "reset" on the transmitter and the receiver should display the following in the DEBUG window:
The RTX-12 Transmit.BS2 and RTX-12 Receive.BS2 programs have a 16-bit checksum to verify data integrity. These programs are documented for ease of use. You can simply change the data in the EEPROM to send different strings or values.
Resources and Downloads
  • RTX-12OEM modem documentation from Tigertronics web site www.tigertronics.com
  • American Radio Relay League web site www.arrl.org for licensing and band plan
  • Example BASIC Stamp 2 Source code (in this post, zipped)
    -·Full demo source code RTX-12 Transmit.bs2 and RTX-12 Receive.bs2
    -·Simple demo source code RTX-12 Simple Transmit.bs2 and Simple Receive.bs2
  • Amateur radio equipment reviews on eHam.net http://www.eham.net/reviews/
Contributors
Chris Savage helped significantly by writing the complete code example and debugging the hardware. John Olson from Tigerbotics provided a quick review of my project for accuracy, too. Jim Ewald (IT Guy) on the forums is an experienced·ham operator and was most helpful in the tests we conducted at Parallax. Jim recently set up a ham station and antenna on the roof of our building so you'll probably see more radio projects from us in the future.
Post Edited (Ken Gracey (Parallax)) : 10/23/2008 4:33:04 PM GMT
  • NR1XNR1X Posts: 111
    edited 2008-10-23 10:07
    Great Project Ken!!! I cant wait to play with this one. not the same modem i have been trying to get going with, but maybe i'll try the tigertronics modem.. don't have time now but im sure once i look over the code i will be enlightened.. curious to see the modem and what mode it runs in?? KISS ?? Any ways great project ,and great to hear that you guys have a station set up! looking forward to many more great ham projects! oh yeah, ill be sure to send all my ham buddies here to see your work!!
  • uxoriousuxorious Posts: 126
    edited 2008-10-29 18:29
    So, any chance of a Parallax operated repeater station coming?
    ~~ dRu ~~
  • edited 2009-05-04 18:29
    I was wondering if one could send byte data? say have sensors sending information through a variable kind of like the RF modules? This has also sparked my interest because I want to build high altitude weather balloons and have sensor feedback.
  • FearTurtlesFearTurtles Posts: 89
    edited 2009-05-20 13:18
    Legal question? Are you sure that it is legal to use the FRS radio in such a manner? It seems to me that in doing so it would still require a HAM licence. Even then might not be legal.
  • SRLMSRLM Posts: 5,045
    edited 2009-05-20 14:48
    @FearTurtles
    A quote from the article:
    Ken Gracey said...
  • LeonLeon Posts: 7,620
    edited 2009-05-20 19:22
    I think that FRS radios have to be specially certified for data transmission.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-05-20 20:00
    Here is some info on FRS data transmission rules.
    edited 2009-05-20 20:03
    @SRLM
    @Leon
    I just did a quick search and it seems you are correct. Even still you are not allowed to connect any device to the radio unless it is Fcc APROVED. Here is the Url of the info. http://www.provide.net/~prsg/frs-faq.htm#Q15 To me it seems cheaper to get a ham ticket then to get a device FCC aproved. LOL
    Edited: The URL is the same as the link in Leons post.
  • Sleazy - GSleazy - G Posts: 79
    edited 2009-05-21 13:03
    Dudes, the answer is simple. Digi's XSC 2.4Ghz band radios GIVE YOU 15 miles with only 100 MILLIWATTS. IEEE 802.15.4 wireless PAN network standards! The module is the size of a pack of matches, and probably weighs less. AAAAH and those frs radios are 5 WATTS?!? Digi even makes a long range 900Mhz module that can get you 40 miles LOS with just 1 WATT. Thats it. JUST ONE WATT. ALL ISM BANDS. NO LICENSES. ASYNC SERIAL - TRANSPARENT OPERATION - OR API. NO NONSENSE....however when I talk to DIGI's application engineers they really dont seem to know what theyre talking about... Which is ok, because the manual is big (but done well I might add)
    Bonus!! you dont need to use that modem inbetween. The Digi modules have an integrated microcontroller/modem within the radio. And its error correcting!! They create networks that are SELF HEALING. If youve got a network and a module drops, it automatically heals itself. If you have more than 2 modules which source and destination modules are out-of-range, they'll use each other to route AUTOMATICALLY. Like a bucket brigade almost. Oh yeah, its got a integrated development environment for your pc, plugs right into an FTDI chip for your usb pleasure.
    PLUS! The Digi radios use DIRECT SEQUENCE SPREAD SPECTRUM! 16 channels. AND , the digi modules have 128 bit AES encryption! Good luck hacking that.
    PLUS! The modules are their own repeaters! End devices act like routers when they AUTOMATICALLY figure out the easiest way for themselves to re-organize a dynamic network, and do it on their own. They also do cyclic sleep routines! Which modules in the network sleep and wake synchronously for updates according to a sync signal from a designated sleep coordinator. Super low power... just 50uA current while sleeping. THE LOWEST expense in juice you can imagine.
    AND- modules have multiple analog (and digital) in's. 250,000bps transfer rate max, down to 1200bps, remotely selectable. 2 PWM output channels. I just looked at the RTX-12, it says the modem doesnt do 4800bps?!? ..... what?....they cant do standard 4800bps gps signals?!?... How do you expect to do telemetry? Time of flight doesnt seem possible? ADXL321 and dead reckoning?.... lol.. They must expect you to walk around with a laptop in a backpack.
    WOW, i almost forgot, they are 3.3v modules! It looks like youve got to use 7.4v for that radio of yours. Yikes! A Digi Zigbee and a propeller host makes such a nice 3.3v combo.
    It seems pretty straight forward... 3.3v, longer range, lower power, faster, LEGAL, smaller and lighter, integrated modem, automatic repeater/routing, automatic acknowledge/checksums, sleep modes, automatically healing networks, OEM modules, and a heck of a lot cheaper. BUT HEY, WITH HT YOU CAN MOONBOUNCE, which seems like the only advantage of HT i can come up with. ( You might be able to moonbounce zigbee modules too, but i dunno. )
    I can hook it up....keep your cellphone close today...
    edited 2009-05-21 14:53
    @Sleazy - G
    15 miles on 100 milliwatts. Thats with a 24dbi gain antenna and clear LOS. Even then it would be flaky at times. NLOS you would be reduced to about 300'. 900Mhz does work better and you can get up to about 4 miles NLOS provided that you only use about 5 Mhz bandwidth. Anything more and you drastically reduce the range. Both require high gain antennas. With the 2 meter HT you don't need high gain antennas and can achieve 40+ miles LOS. In most cases you would run the HT on low power which tends to be 100mw to 1 w depending on HT. Depending on location 900Mhz and 2.4gig bands can be quite crowded
    In the end 2.4 gig is ideal for high bandwith LOS /Fixed station communication or short range omni directional NLOS. It is about the most enexpensive way to do things.
    900Mhz (4watts PEP Max) improves distance over 2.4 gig at a reduced bandwidth. In NLOS conditions you need to reduce the bandwidth to 5Mhz to really get penetration. This should not be a problem seems how the BS can only handle about 9600baud anyway. With 5Mhz you can get about 900KB datarate. The price goes use quite a bit here. To get the best range you really need 15dbi antenna's which add about $75 bucks per unit although if you are willing to go the home brew method there are some nice designs on the net that can drop the cost to around $25. Over all the cost would be about the same as if you were a Ham using 2 meter or 430Mhz.
    Unless your a Ham I think 430Mhz is out of the question unless you happen to fall into the legal data transmittion criteria. Even then everything has to be FCC approved. As far as I know you can run data such as RFID at very low wattage to only transmit a few feet. You can probibly get away with using the FRS handy talkies but it would be illegal.
    2 meter is not a public band but offers the most reliable choice of all. It is limited to no more then 56k baud which is really expensive to get into. People have already been using the band for applications which the BS2 would easily fall into. It would cost about $155 or less per unit if you pick up the HTs used. (now where did my HTX 202 go?)
    The basic rule of thumb is that the lower the Freq. the better it will preform but will be limited in baud rate. But with the Stamp baud rate is low enough for any of the bands in question. You can Moon bounce on 900 Mhz as well. You can also bounce off of Mountains if they are rocky. wink.gif
    edited 2009-05-21 16:27
    Right, the guys at DIGI were saying directional antennas were about the only way to get the max ratings on those modules. Im not trying to "bust ken's balls", cause its awesome what he's doing. It's more like trying to sway the project in the right direction. What I see as the right direction. I dont want the FCC cracking down on anyone...They'll fine someone half-a-million dollars for saying "(expletive)" on the radio.
    civilian FRS/amateur radio is limited to 500mW, so ken is already over by a factor of 10. (dont "microwave" anyones brain!) Zigbee is limited to 1 watt, so its double the legal FRS power output values values. Ive heard reasonable quotes on distance NLOS right around 1-1.5 miles, around where the best zigbee modules are in realistic terms.
    In the digi radios, the repeater costs you the same as a module, because the repeaters ARE modules. The antennas are relatively small and light. However, HT repeaters ive seen seem something the size of a refrigerator, or a car, with antennas the size of the washington monument, whereas you can put a zigbee module on a balloon and FLY the thing as a repeater/router. Its legal under a certain height to fly a module like that (i cant remember exactly) and under 15 lbs. Those HT repeaters cant do that in the same outline.
    The direct sequence spread spectrum takes care of the "flakyness" by altering penetration signatures and traffic/collisions by shifting through the bandwidth of available wavelengths with a noise carrier to acquire acceptable readings, re-assembling the data by cancelling or "de-noising" the "chips" (which are going to chirps) does somewhat of a "differential measurement", like DGPS. The "chirps" of the new zigbee protocol are fabled to do ranging within a meter. Narrowband interference of HT is bad, whereas the large bandwidth of the Zigbee module's spread spectrum is highly invunerable to interference. We're dealing with data here, so one mistake can be catastrophic. Your cell phones do something similar to DSSS, called frequency hopping spread spectrum, but they hop randomly instead of predictably. The idea behind FHSS and DSSS are practically the same, its just a bit harder to hack FHSS. The spread spectrum jumps through samples it puts on its "noise" carrier, and has such a large bandwidth that it can actually exceed the width of the data being sent. The signal looks like white noise. HT looks like a normal FM signal, and is easily heterodyned or hacked. Phase shifting from travel can mess up HT because it does lie in such a strict bandwidth. In the DSSS, each frequency shift "error" should "average" out over the noise "carrier" signals. A bad way to explain it, but kind of correct.
    GPS baud rates are 4800bps generally and the RTX-12 can only handle 2400. Thats the biggest problem with trying to get "high" bitrate signals (like a GPS module) on the HT radio as you said. Plus, the amount of modulation from heterodyne traffic in such a small amount of data could cause GPS readings to be faulty, and you wouldnt even know! If a zigbee communication goes bad, it retries automatically, and then drops if there's complete failure after a few more attempts, and acknowledges it. With HT you'd get stuck with accepting a bad reading. RFID tech these days shows this principle. Its intuitive that a higher frequency signal has greater invunerability to interference, but greater vunerability to shielding, HOWEVER, since zigbee uses the same 2.4ghz and 900mhz frequencies as does generation two RFID readers/tags, BUT SPECTRUM SHIFTS, you dont run into the shielding problems so much as with RFID in the same band, and you still get to reap most of the distance benefits of the higher frequency. Theres just not enough bandwidth for HT to do the same, and to avoid all the traffic. With zigbee spectrum shift, you get something like 10 million separate virtual channels, which CANT phase shift each-other coherently, due to their "white noise" look. I sound like a broken record now. If you could just get a reliable noise carrier signal over the FRS bands to lay the data on, and linear feedback shift register somehow.
    Why not put them both together
    Post Edited (Sleazy - G) : 5/23/2009 5:26:49 PM GMT
    edited 2009-05-21 17:29
    I think the reason for the 2 meter band having such huge repeaters and antennas isnt just its wavelength being so large (at an attempt to harmonically induct), is that the main repeaters are "trunked" alot like old phone systems before everything went digital. Every repeater/digipeater you add in line with 2-meter, you gradually degrade the signal, so its better to have just a few main "trunks" to send most of the information to, doing just a few "repeats", whereas 2.4ghz and 900mhz, although more shielded, will have zero UNKNOWN packet loss, unless you got really lucky and you received the same exact "random" interference 3-4 times in a row or something...and that includes a 128bit AES encryption, which must stay the same through every automatic "retry" after a transmit "failure", in certain modes. So , you can just load up an area with zigbee modules and set them up as repeaters, and not have to worry about FSK in the Digipeaters that operate in the 2 meter band. I guess the newer digipeaters send acknowledge signals alot like the zigbees do.
    I imagine you could get a great moonbounce with the zigbee modules on a clear day, and with little problems with the noise carrier differential calculation behaving almost like a GPS sattelite. You could probably put a few modules on the moon, and use them as repeaters, with some solar cells maybe. [noparse]:)[/noparse]. Thats what 802.15.4a is going to be, but in shorter distance, with "chirp" instead of "chip"
    OK... I THINK I just found HOW KEN INTENDED ON DOING THE TELEMETRY. Automatic packet reporting system! I just read this. I know something similar had been done before, but i couldnt remember what it was called. The signals were just transferred so many times that the differential of its path history was resolved. This is actually a differential systems like GPS, but the APRS worked like zigbee module networks, where nodes hop in proximity, which in itself provides information. About speed ...
    ...Ways to achieve higher speeds than 1,200 bit/s, include using telephone modem chips via the microphone and audio out connectors. This has been proven to work at speeds up to 4800 bit/s using fax V.27 modems in half-duplex mode. These modems use phase shift keying which works fine when there is no amplitude shift keying, but at faster speeds such as 9600 bit/s, signal levels become critical and they are extremely sensitive to group delay in the radio."
    Custom modems have been developed which allow throughput rates of 19.2 kbit/s, 56 kbit/s, and even 1.2 Mbit/s over amateur radio links. However, special radio equipment is needed to carry data at these speeds, and their adoption has been limited. In these special radios, the interface in between the "modem" and the "radio" is at intermediate frequency -part of the radio disregarding parts of the radio that were used for voice modulation production and detection.
    In commercial data radio uses the intermediate audio stage is dispensed with, and bits are transmitted by directly altering output frequency in between two distinct frequencies (in case of FSK modulation, other alternates do exist). Such radio modem chips are now available, but as they are incompatible with previous Amateur Packet Radio technologies, they have not been adopted into amateur radio use."
    ..... so you can use the audio channels as a modulation signal on top of the 145mhz pre-FM data. Tricky. Thats what you need to do. More from what ive been reading.....
    "Byonics has introduced an all-in-one device combining a GPS receiver, TinyTrak controller and synthesized 2m radio called the Micro Trak AIO which requires no assembly by the user.
    ArgentData now has a 5-Watt VHF Transceiver with Integrated Tracker2 in one compact package. With a non-display GPS receiver connected, the T2-301 can be used as a tracker. With compatible display-type GPS receiver, received position reports can be output as waypoints. With a Garmin Nuvi 350 GPS receiver connected, it can send and receive APRS messages as well as display other stations as wayoints. The Nuvi 350 can be used this way with a stand-alone Tracker 2 (OT2m) or connected to a T2-135 which mounts in an Alinco DR-135 radio. The T2-301 can also be used as a stand-alone digipeater. Just connect an antenna and power, and program it, and it's ready to go.
    The aprs SkyTracker is an APRS Beacon at 144.800Mhz which includes a 8W RF Transmitter, programmable PIC & u-bloc GPS receiver all on one 72x56mm PCB."
    Sounds like what youve got there.
    Oh, and as I was saying earlier, that putting the 2 meter radios with the 2.4Ghz and 900Mhz zigbees cooperatively CAN WORK, CHECK THIS OUT
    "One notable detail is that 2.4 GHz WLAN band is partially overlapping amateur radio band, and thus WLAN hardware can readily be used by amateur radio licensed operators with higher power radio gear than what the general population "license free" usage allows. ("Free to receive by anybody", "transmit only between licensed radio amateurs", and "no encryption" rules usually make these very unappealing to spend time on.) Regulation details differ around the world.
    So maybe we can work around the law... :P SO YOUve got an APRS NODE - DIGIPEATER in CALIFORNIA - callsign
    N6EX-4 San Joaquin Hills, California [noparse][[/noparse]show location on an interactive map] 33°36′21″N 117°48′38″W
    Maybe something to test off of. I think we should make something together with this now, mix the best of 2.4Ghz/900Mhz and 2 meter. You'd think if one was failing, the other could "come through" for you. And if you can get around FCC power regulations by using 2.4ghz/900mhz equipment with the 2 meter wavelength, theres no sense in NOT multiplexing them.
    Jeez... im thinking about this way too hard now. More later.
    edited 2009-05-21 23:43
    @Sleazy-G
    LOL Wow just skim over your two posts, I will have to reread them later because it appears you made some interesting comments. It does seem like getting the full 56k baud on 2 meters should be easier then the current method. You can go up to 9.6k easy enough.
    edited 2009-05-22 13:43
    FRS radios sell with power rating as high as 5 watts. Amateur radio Operators can run 1500 watts PEP on 2 meters and 70cm provided they are not in a restricted area. Basically any of the bands discussed here can be used within there limitation. 900Mhz is the best all round band for high data and reasonable range. Having an Amateur Licence give some advantages reguardless of the bands. In 900Mhz a Ham is till limited to the 1 watt transmitter power but is not limited to the amount of antenna gain. So you can achieve about 32watts PEP with a 15DB gain antenna. There are restrictions such as the transmmitter must have automatic power control but you get the point. On 2.4gig and above you have to limit the transmitter power depending on the antenna gain but even then you can achieve high wattage PEP systems.
    I think Ken has a great Idea here where you can communicate to a robot over long distances. Or you can even using it to control X10 devices remotely. I would really like to see this ported onto the Propeller as then you can handle higher data rates and string lengths. I have been toying with the Idea of building an APRS Propeller station for my car which would allow me to connected a display/Keyboard to a Kenwood D700 to create a full APRS station. But right now I have other pokers in the fire which need to get completed.
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-08-15 13:58
    Stacey said...
    What are Ham Radio Antenna Towers? what are the purpose of an antenna tower?
    http://www.tech-faq.com/ham-radio-antenna-towers.shtml
    Antenna towers hold the antenna in position, raise it above surrounding objects on the ground to improve transmission and reception, keep transmitting antennae away from people/animals that could be harmed by the radiated energy, and provide a way of pointing directional antennae. Antenna towers are typically just sections of metal pipe with cross reinforcing pieces and mounting hardware at the top and bottom.
    edited 2009-08-17 22:15
    FearTurtles said...
    @Sleazy-G
    56k is impossible on 2m!
    Leon
    edited 2009-08-18 04:49
    leon said...
    What?!! That's ludicrous, Leon! It all depends on transmit bandwidth. And the 144-148MHz band has plenty of spectrum available for a 56Kbps signal. Is such a transmission legal? Well, that's another matter. But technically? Sure! If you can transmit 56kbaud over voice-grade phone lines, it surely ought to be possible over a wideband RF link!
    edited 2009-08-18 10:11
    Anyone doing it on the 2m band would be very unpopular, to say the least, and no radio on the market will manage it. In theory, it could be done with a GRAPES-type modem (it uses a 29 MHz IF) and a 2m transverter, but it will be rather expensive.
    Leon
    Post Edited (Leon) : 8/18/2009 11:49:45 AM GMT
    edited 2009-08-18 16:20
    Here's a link to a 56K modem designed for ham operation: www.wa4dsy.net/rfmodem.html.
    edited 2009-08-18 17:08
    That's the type of modem I mentioned. It will only work with a transverter, and is only suitable for UHF and microwave bands..
    Leon
  • Brian KnoblauchBrian Knoblauch Posts: 3
    edited 2009-09-06 18:52
    Just to clear up a little confusion above. FRS permits 500mw. GMRS permits greater. Those 5w "FRS" radios are actually combo FRS/GMRS radios. You need a GMRS license to take advantage of the higher power (and the rules have some other differences, such as needing a callsign, but allowing more interesting uses than what FRS does, etc). Generally speaking, an amateur radio license will let you do up to 1500w. There's some band restrictions and of course, there's safety limits that must be considered. Improving the antenna almost always beats upping the power anyways... smile.gif
  • SpigiSpigi Posts: 4
    edited 2009-09-14 15:34
    I stumbled on this thread while looking for a solution to a problem. We run a two car race team and we need simple pit-to-driver and driver-to-pit communications. The system I would like to build would be a set of lights in the cockpit of the car that would tell the driver the condition of the track (green, yellow, red flags) and when to come in to the pits for driver changes and fuel. We also need a "Pit" button for the driver to press when they plan on coming into the pits so we will be ready for them.
    I had though about using the Parallax 433 MHz RF Receiver/Transmitter modules, but we need a range of 0.5 to 1 mile. I had also thought about using FRS radios, but there are problems with the interface, especially activating the PTT switch.
    Are there any simple Rx/Tx modules that have the range? Will the XBee-PRO be easy to interface to the BASIC stamp?
    Thanks!
    Andy
  • stamptrolstamptrol Posts: 1,731
    edited 2009-09-14 16:43
    · Andy,
    ··· Digi (formerly Maxstream) makes some really nice 900 MHz, 1 Watt standalone wireless modems that interface easily with Stamps and will allow your required 2-way data flow. Have a look on the Digi website for the XTend products. Also available through DigiKey.
    · If you want to discuss further, we can move over to the Sandbox.
    Tom Sisk
    http://www.siskconsult.com
    Tom,
    Thanks for the reply. I think the Digi modules may well do the job.
    Thanks again,
    Andy
