ADC.spin - Need help!
I am using the wiring example here, and apparently, I can just use the ADC.spin in the propeller tool library. However, I am having a bit of trouble understanding how to use it. How can I retrieve the value?
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
Brandon C.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Brandon C.
Example:
ADC.SigmaDelta(@adcvalue) 'start cog with sigma-delta ADC REPEAT DEBUG.dec(adcvalue) DEBUG.tx($D) waitcnt(clkfreq / 10 + cnt)Something like that. Let us know. I have no way to test it where I am.
But the value won't go below 32,000. is that normal? or is it the circuit?
Won't go below 32000 (exactly) or 32767/32768?. Try wiring the input directly to ground or directly to 3.3V.
Someone who is familiar with all this stuff should chime in eventually.
Yeah, sorry. I meant 32767.
Brandon C.
