Prop to prop coms using Fullduplex serial
Why wont this work
I need to make a type of repeater from a computer to a propeller to a propeller.
Serial.rx(Prop.TX) Prop.RX(serial.TX)
You'll need some kind of loop for that. Also, I'm not sure but setting one of the mode bits for FullDuplexSerial might do the same.
--Steve
Propeller Tools
assuming you are using FullDuplexSerial
you get an error "expected end of line" because serial.rx has NO parameters
you can find this by looking into the sourcecode of the method rx
rxbyte is a RETURN-value and NOT a parameter
you have to code it vice versa
you still might have a problem if no bytes were received as the method rx waits for a byte to be received
if no bytes were received rx will wait for 2 Billion years until the exploding sun will melt the chip
so to make it run "double-fullduplex" you could use rxtime to avoid long waitings
depending on how many bytes come in you might have to increase the buffersize (standard is 16 bytes)
to avoid loosing bytes in the circular buffer of fullduplexserial
best regards
Stefan
Post Edited (StefanL38) : 9/11/2009 7:20:09 PM GMT
