ds1302 and professional development board
·I hooked up the ds1302 on the pdb and got everything working fine. I am using the object from the object exchange. I hooked up a battery to the green posts and verified the voltage at 6.5vdc. I moved the jumper to ext.
When I turn off the pdb the ds1302 goes back to 0 on everything.
This is the config subroutine from the ds1302 object. I have tried removing the config and the settimedate from the program when I load the eeprom.
I have also left the config in and just removed the settimedate.
code·
PUB config
· write($90,$a6)······ ' Init chargeing register 1010 0110·· charge activée une diode , R=4K
· write($8e,0)········ ' Init write-protect bit
· 'x := read($85)······ ' read register
· 'x &= %01111111······ ' reset bit 7 (12/24h cycle)
· 'write($84,x)········ ' write 12/24h cycle
· write($84,0)········ ' write 12/24h cycle
· x := read($81)········ ' read clock halt
· if x & %10000000···· ' If not clock halt
··· write($80,0)······ ' enabled clock halt
·/code
Any help or suggestions?
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Post Edited (mosquito56) : 9/10/2009 11:51:41 PM GMT
code·
PUB config
·/code
You probably do not want to connect >5v to the battery, so consider using something other than the 6.5v battery you originally tried.
Post Edited (Agent420) : 9/11/2009 11:43:21 AM GMT
