Something different, (but very retro)
Bet you've never done this!
Connect to a Commodore 64 BBS from your Propeller. <SMIRK>
Attached is a simple terminal program (PropCOMM)
[noparse][[/noparse]Here's how:]
It is configured for 9600,N,8,1 (fast enough for this)
Uses standard demo/proto video/keyboard setup.
Load PropCOMM into your EEPROM, then grab a copy of this program
BBS Server: www.jammingsignal.com/files/
Set the BBS server to the same COM port as your propeller connection, at 9600,N,8,1
From the propeller type ATH and hit enter, if you get an OK back it's working..
Now type (on PropTERM) ATDT BBS.JAMMINGSIGNAL.COM
(The free shell on sdf.lonestar.org works, but the 7 line screen makes it a pain [noparse]:)[/noparse]
If you make it work, you've done this..
PROP<-->PC<-->INTERNET<-->PC<-->COMMODORE64
sic,
Oldbitcollector
Edit: cleaned up the code a bit more & fixed backspace (mostly)
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Cavin and Hobbes.
Post Edited (Oldbitcollector) : 9/16/2007 2:33:27 AM GMT
sic,
Oldbitcollector
I found this old posting.
I have a commodore128 and was wondering how to get games onto it without a floppy drive. This seems like it might be a solution.
What I was wondering, however, is how you make the connection from the PC to the commodore.
Doug
OBC
New to the Propeller?
That is something that make my C128 a lot easier to use,
what about the connection to the PC?
Doug
Schematics toward the end of the document.
OBC
You are quite the Commodore resource.
What were you able to do with this?
Were you able to download programs into the commodore from the prop and run them on the commodore?
OBC
At 9600 baud though, it could load the c64 memory in about 68 seconds. I am guessing that tape is somewhere like 300 baud.
It's too bad we don't have a propeller 1571 emulator. Now that would be cool, but since it has been done with AVRs and such, I would guess that the demand is not that high.
If we could just get goog back here to finish the c64 emulator. With xmm it should be a lot easier than when he was trying it back then.
Doug
BTW: The datasette theread is at http://forums.parallax.com/showthread.php?p=695936
I have made some attemps at making a 6502 emulator in pasm.
Conclusion..... it would be possible to make a 6502 emulator running in one cog.
All my experience in making my "PC engine"/"Turbo grafx 16" emulator has gained me a lot of knowledge of the 6502 (the HuC6280 used in the PC engine is an extended 6502)
This helps me very much in the task of making it fit in a 512 longs PASM code.
Maybe the time has come to unveil my latest prop based C64 project.
I have made a SID-emulator running in one cog and outputing a stereo signal at 33.250 khz sample rate.
It currently emulates
- Square wave with variable PWM
- Triangle wave
- Saw wave
- Noise
- Ring modulation
- Sync modulation
- ADSR envelopes
It does not emulate
- Filter
- Combined waveforms
- SID bugs
When we have every chip emulated in one cog each and some extended memory, a C64 emulator would be possible.
We currently only have the SID chip emulated(somewhat).
Potatohead was/is busy working on the 6502 here http://forums.parallax.com/showthread.php?p=767703. Haven't heard any progress reports on that for a while.
The Z80 case was a lucky hit for us as most of the CP/M software we want to run only uses 8080 opcodes and they all fit in COG. The extra Z80 ops are done by using PASM overlays which is slow but no worries they are not used.
We get the same or better performance than an original Z80, but I suspect if we were running code that used a lot of Z80 specific ops it would not look so good.
The Motorola 6809 is a bit more of a beast. Takes a lot of code to emulate all it's addressing modes and such. So there are a lot of ops farmed out to PASM overlays. Unlike the Z80 all ops are important so it's a tad slow. I'm looking again at a 2 COG solution for that.
In the end all 149 opcodes can be emulated in a relatively little space. (fit in one cog)
Have a look at www.llx.com/~nparker/a2/opcodes.html
The thing is that i don't feel like diving into yet another project right now..
Does anywone own a whip or blowtorch to help "motivate" Potatohead in his quest of finishing the emulator ?
Then we can make a SID-player using my SID emulator + Potatoheads 6502 emulator + Rokickis SD card driver.
Holy Cow.. You've just expanded the Propeller music library by about a factor of 100.
Looking forward to playing with that. [noparse]:)[/noparse]
We have most of the pieces for a C64 emulation project if we went multi-propeller on this.
OBC
The 6502 may have a simpler more regular layout of its opcode bits so you may have more luck but I thought Potatohead had come to the conclusion that the ZiCog model was going to work better.
Are you thinking about the HVSC ?
I'm sorry but we need to have an emulated 6502 to be able to play those.
As of now, you can only poke values in the 25 SID-registers from your Spin/Pasm program the same way a C64 6502/Basic program would.
I have made a SID-dump player to test my SID-emulator.
It works by dumping the 25 SID-registers from a real C64 at a rate of 1 VBL(50hz/60hz) into a byte array.
Then my SID-dump player just feeds my emulated SID with these bytes at the same rate.
The problem is that these dumps can be VEEERRYYYY big.
I have attached an example of my player with an 8 second SID-dump loop. (Can't fit more in 32kb)
It works on the default demo board audio configuration.
So what we need is a PC utility to dump .SID then load it from the SD.. [noparse]:)[/noparse]
I'll try it tonight and report back! Glad to see any progress on that front.
I still know many C64 guys who would bow and worship at the feet of someone
who pulls of decent .SID playback on the Propeller. (Heck, I'd set the rugs out for them. [noparse]:)[/noparse]
OBC
Looking forward to more of this!
OBC
OBC
Of course it does
It is very accurate, i have done my homework, reading some indepth documentation.
Probably easier than coding a 6502 emulator, but is it worth it?
That format is extremely limited, it doesn't make use of the full potential of the SID (sounds more lika a NES)
We should start a new thread for this project.
Good point.. .MUS was early on with SID music, although I remember having some rather
good collections of MUS music that I wish I could lay my hands on now. A lot of good 70's-80's
SID music. Then there was Craig Chamberlain's SID editor that wasn't bad for that format either.
At your leisure...
OBC
