Sigma-delta/TV_text problem
Help, someone,
For some reason this code doesn't quite work the way expected. Appears the ∑-∂ A2D works, because it supplies variable values back to Spin. And if the ' djnz hpix,#:loop' line uses ':initloop' instead the TV_text output works, but no output with :loop.
I took the ∑-∂ code from AN001, and that worked fine. But after I added the 40 sample loop it didn't. Anyone spot what's not right?
Pin group 12 is used for TV_text.
Harley Shanko
'* Sigma-delta A-D converter for HPulse sensor signal DAT org 0 ' 'entry ' --- Debugger Kernel add this at 'entry' --- MUST BE LAST COG IF USE 'PASD' ' long $34FC1202,$6CE81201,$83C120B,$8BC0E0A,$E87C0E03,$8BC0E0A ' long $EC7C0E05,$A0BC1207,$5C7C0003,$5C7C0003,$7FFC,$7FF8 ' -------------------------------------------------------------- A2D or DIRA,Msk8 ' make A8 an output or DIRA,asm_dira ' make A2 (pin 3)(ADC) an output movs CTRA,#adcpin ' POS w/FEEDBACK code ??? movd CTRA,#fbpin ' movi CTRA,#%01001_000 mov FRQA,#1 mov asm_cnt,cnt add asm_cnt,asm_cycles :initLoop mov hpix,#40 'count 40 character/width of screen mov ptr,PAR ' init ptr to begin of locations andn OUTA,Msk8 ' set marker LO TEMP nop ' extra wide to view start or OUTA,Msk8 ' set marker HI :loop WAITCNT asm_cnt,asm_cycles ' wait for next cnt value andn OUTA,Msk8 ' set marker LO TEMP or OUTA,Msk8 ' set marker HI mov asm_sample,PHSA sub asm_sample,asm_old ' WHAT'S THIS DOING ???? add asm_old,asm_sample ' wrlong asm_sample,PAR ' write value to RAM wrlong asm_sample,ptr ' store a sample add ptr,#4 ' increment to next long djnz hpix,#:initloop ' WHY NO TV OUT W/ ':loop' jmp #:initLoop ' ' Initialized data asm_cycles long |< bits - 1 ' sample time asm_dira long |< fbpin ' output mask Msk8 LONG |<8 ' TEMP - for time marker on A8 ' Uninitialized data ptr RES 40 ' holds pointer to PAR, for 40 long samples hpix RES 1 ' #samples counter asm_cnt RES 1 asm_old RES 1 asm_sample RES 1 FIT 496
Harley Shanko
What does par get initialized with? It needs to be the address of a long array in the hub that's at least 40 longs long. Your ptr array does not exist in hub memory at all, BTW, since you've used res to define it. What I'm getting at is this: if par is initialized with @ptr, writing 40 longs to that address in the hub is going to clobber a lot of stuff that that "array" overlaps, possibly including some of the video stuff.
Post Edited (Phil Pilgrim (PhiPi)) : 9/10/2009 2:12:37 AM GMT
Thanks Phil. I think you've pointed out the error of my ways; forgot to make an array at where par points. Too close to the 'forest'; "what trees?"
Yes, that way what was missing, the array, therefore it was overwriting some other variables. 'New eyes' on a listing makes a huge difference, plus different experience to recognize the missing stuff.
Harley Shanko
Post Edited (Harley) : 9/10/2009 5:54:28 PM GMT
