Plug and stay – reliable connector wanted — Parallax Forums
vaclav_salvaclav_sal Posts: 451
edited 2009-09-10 15:03 in General Discussion
I need some advice regarding a reliable 5V DC max 100 ma connector.
I am considering automotive “solderess” spade or bullet type,
telephone RJ11/ RJ45 and standard PC Molex ( 5/12V).
It needs to be semi outdoor type, easy to connect / disconnect and capable of being reliable after 25 to 30 connect/ disconnect a day for at least a year.
No screw on type or wire nuts.
Any comments on mini USB?
Any help is appreciated.
Thanks for reading.
    edited 2009-09-09 14:26
    mini usb has tendency to fall out easiyl after repeted inserts.
    pc molex are not always eawsy to insert but tight and do not fall out
    rj11 and rj45 are very easy and reliable as long as tab does not get broken off and i have seen water tight connectors
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-09-09 17:03
    vaclav_sal,
    How many conductors? If it's just two, then I would consider a standard RCA Phono Plug for the job.
    Beau Schwabe
    IC Layout Engineer
  • ManetherenManetheren Posts: 117
    edited 2009-09-09 17:36
    for a reliable 2 or 3 conductor you could use BNC as these are only 1/4 twist. They last for lots of connections and disconnections.
    Tia'Shar Manetheren
    edited 2009-09-09 17:57
    vaclav_sal,
    25-30 matings/unmatings per day? That's a lot, so let's back up a little bit. (It's always useful to examine one's premises in a case like this.) It there any reason you can't just leave it connected and switch the power on and off?
  • vaclav_salvaclav_sal Posts: 451
    edited 2009-09-09 18:49
    Guys - many thanks for replies.
    The intended project is a small remote device running on battery which lasts approximately 10 minutes.
    Therefore the battery needs to be removed / disconnected / replaced to keep the device in service for full shift. The 25 to 30 disconnect per day / shift is just a rough estimate.
    I did not think about the RCA plug, they seem to be reliable but little bulky.
    However, I will definitely stay·away from anything phono mini or·sub mini or USB.
    I have a fairly expensive ham radio rig with some phono plugs are they are a big headache.
    Cheers Vaclav ·
    edited 2009-09-09 19:29
    For reliability in hostile environs, I'd settle for nothing less than a cordset/receptacle pair from Turck.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-09-09 19:41
    I'm just putting this out there because it's the first thing that came to mind, you'd have to make it yourself (unless they are commercially available?).
    Two pair of 1/8" neodymium magnets. One pair molded into the end of the cable, the other on the device. The magnets make the electrical connection and a good mechanical connection that breaks free without damage.
    Rich H
    The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
    edited 2009-09-09 20:43
    Rich,
    Hmm, interesting. And if they have opposite poles facing outward, you can't connect them wrong! Can you solder to them, though?
    edited 2009-09-09 21:14
    I think they are typically coated in nickel, and they lose their magnetic strength at high heat so soldering directly probably wouldn't work well.
    Rich H
  • TubularTubular Posts: 4,768
    edited 2009-09-09 21:47
    Rich, that's a really good idea.· I like the inbuilt polar repulsion "feature" if you get them around the wrong way.· Plus they would self align...
    You can buy these in pairs for under $2 with wires already welded
    http://www.altronics.com.au/index.asp?area=item&id=P9192
    and smaller
    http://www.altronics.com.au/index.asp?area=item&id=P9190
    Vaclav, I'd imagine you'd be able to find them locally; if not I could send them (if·you want to use this appoach)
    Post Edited (Tubular) : 9/9/2009 9:54:30 PM GMT
  • TimmooreTimmoore Posts: 1,031
    edited 2009-09-09 22:21
    Magnets are used for battery connections on microfliers http://www.microflight.com/Online-Catalog/Batteries-and-Chargers/LP90-FR-Bahoma-Cell-with-10mm-Bahoma
    sparkfun has some magnetic connections for the lilypad stuff. http://www.sparkfun.com/commerce/product_info.php?products_id=8682
    edited 2009-09-09 22:46
    I was actually thinking about a spring-loaded arangement (similar to the old fashioned AA /AAA battery holders) and I like this magnetic approach better.
    It would greatly simplify the battery exchange process and maybe the process could be automated.
    Build some kind of docking station where the magnetic connection could be demagnetized and the battery would then drop out automatically and the fresh one inserted by reversing the process.
    But I am getting ahead of myself here.
    Thanks to all who contributed so far to the discussion.
    edited 2009-09-09 23:28
    Vaclav, I'm more concerned with the 10 minute battery life and the constant vigil required to swap over battery packs. Can't you use a bigger battery, or change the design to draw less power? What's the problem here or would you care to elucidate us on the application here?
    *Peter*
    edited 2009-09-10 02:34
    I'm with Peter — back to examining premises. Not that we don't want to help solving the stated problem, but it seems that there's a much larger, underying problem that demands even greater attention.
    I am not ready to "go public” with details of the application.
    Sorry.
    I am stuck with strict specifications.
