new user multi input help required
                    Hi,
can anyone help me with how to read 4 input pins
from table below,inputs from switch are multiplexed,how do i read all 4 inputs & run a subroutine for
each of the six input statements.Looked in manual & got totally confused,i think i need a lookup table ?
switch Table:
input pin ·5·6 7 8
· gear··· ·A B C PA
······· P = 1 0 0 1
········R= ·1 1 0 0
········N= ·0 1 0 1
········D= ·0 1 1 0
········3=· 1 1 1 1
······· L=· 1 0 1 0
·using BS2Px board & pbasic 2.5
Thanks Adrian
switch Table:
input pin ·5·6 7 8
· gear··· ·A B C PA
······· P = 1 0 0 1
········R= ·1 1 0 0
········N= ·0 1 0 1
········D= ·0 1 1 0
········3=· 1 1 1 1
······· L=· 1 0 1 0
Thanks Adrian
mynib VAR Nib mynib.BIT0 = IN5 mynib.BIT1 = IN6 mynib.BIT2 = IN7 mynib.BIT3 = IN8 SELECT mynib CASE %1001 : GOSUB A CASE %1100 : GOSUB B CASE %0101 : GOSUB C CASE %0110 : GOSUB D CASE %1111 : GOSUB E CASE %1010 : GOSUB F ENDSELECT▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Don't worry. Be happy
Looks like the answer
regards Adrian
