Using ping and ir at the same time
All,
Greetings from VA Beach.· Hope everyone is well.· Got a question.· My BOE is doing great with PING.· He is going around, finding walls and such, but he doesn't see "clothes" very·well.· ·I am trying to get both·PING and 2 X IR sensors to work at the same time.· I am using a propeller.· Does anyone have a suggestion? Thanks and have a great weekend.
Bob
Freedom is worth fighting for; it will ensure posterity experiences the same. [noparse][[/noparse]Theron Hudson]
Bob
Show us the code that you are using thus far and a schematic if you are able. Since PING and IR do not interfere with one another it is completely possible to have multiple forms of object detection.
Beau Schwabe
IC Layout Engineer
Thanks for helping.· I attached two spin files to this post.· The first is "My6thTest5.spin".· You may recognize it, as I downloaded it (and then modified it), from the ROBOT MAG website (www.botmag.com); Spring 2008 issue.· The schematic (modified for my BOT) is located at the top of this file.· I would like to give credit to the author, but none of the files contained a name.· Anyway, the second file is "TestIrDutyDistanceDetector.spin".· This one may also be familiar.· It's the file on page 152 of the "PEK Fundamentals" book.· This file, I also modified and contains the code that launches the IR process into cogs.· I know that I didn't comment very well as time seems to be a precious commodity.
As I indicated in my previous e-mail, BOE works great with ping... in fact, if you "comment-out" all references to IR in the first spin file, BOE works fine with ping.· I·know·the problem has to do with using the counter modules·and·launching the IR process into a cog.· If your·like me,·you find little time to devote to "outside the family (and work)" projects.···Thanks for anything that anyone can provide.· Have a good one.
Bob
Please use the "File->Archive->Project..." to include all of your object components.
Beau Schwabe
IC Layout Engineer
Here is the zipped file (with all objects).· I will have some time this weekend to work this as well.· But I'm sure that someone with more experience would get to a solution faster.· Thanks again for helping out.· Have a good one.
Bob
Beau Schwabe
IC Layout Engineer
I finally had a chance to look over your suggestion last night.· The file on page 152 includes a repeat loop at the end of the file, that I forgot to include(I feel pretty stupid).· Anyway, I added the repeat command for applicable lines of code.· Still did not work, but I have had a bad felling about the way I used COGNEW.· I ended up calling two objects (one for left IR and one for right IR), and made a few more modifications.· Presto... boe works with IR (with ping disabled). I will get all working this weekend.· Thanks for the help.· Hope you have a great weekend.
Bob
