We need a SIGNED 32x32 multiply and 32x32 divide for PropBASIC. Can you help ?
Bean
We need a signed multiply and divide routine for PropBASIC.
The input will be 32 bits, and the results will be 32 bits.
I looked in the object exchange, but I didn't see anything.
A search of the forum found some unsigned routines.
If you have a routine, or can whip one up, I would appreciate it.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Bean.
Yes it does...
input A, B;
Sign = 1;
if (A < 0) Sign = -Sign, A = -A
if (B < 0)·Sign = -Sign, B = -B
Perform unsigned multiply/divide into result R
if (Sign < 0) R = -R
I would recommend you look for a 32x32=64 multiply routine to start off. If you plan to include the PBASIC operators ** and */ on native longs, you will need it as a foundation. Since Spin includes **, you might find the routine you need in Chip's interpreter code.
' 32 to 64 bit signed multiply asm_x by asm_y ' asm_y absvaled, result in t1:asm_x ' multiply abs asm_x,asm_x wc muxc asm_n,#1 abs asm_y,asm_y wc,wz if_c xor asm_n,#1 mov t1,#0 mov t2,#32 shr asm_x,#1 wc :mloop if_c add t1,asm_y wc rcr t1,#1 wc rcr asm_x,#1 wc djnz t2,#:mloop test asm_n,#1 wz if_nz neg t1,t1 if_nz neg asm_x,asm_x wz if_nz sub t1,#1 multiply_ret retThis is lifted directly from the Spin interpreter, but with the interpreter control logic removed.· You need to declare LONGs or RES asm_x, asm_y, asm_n, t1, and t2; as written in the course of computation the original asm_y gets absolute valued, asm_n is trashed,·and the signed result of the signed multiply is written to the 64 bit pair t1:asm_x.
You can lift the code from my faster spin interpreter. IIRC I increased it's performance from some code Chip posted later. Link is in my signature under Tools.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
